SOURCE: Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
SOURCE: waste toner full prepare new drum on canon iR1570F
The waste toner is part of the drum unit. You need to replaced the drum unit with a new one.
SOURCE: Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
SOURCE: Error: "Toner Low prepare new
Hi
May be u can;t use the original cartridge please buy the Canon Center and try again
SOURCE: Canon MF6590 will not print fax pages if it thinks
this is let you check if your toner really is out:
http://www.quikshiptoner.com/catalog/canon-mf6590-toner.html#When_to_Replace_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF6590_Printer
