Aztec celair Pilot light on. When Low Fan setting is chosen, heater doesn't fire up. Pilot light on. When Low fan setting is chosen, furnace doesn't fire up. with Low Fan setting doesn't comedoesn't fire up at
  • 3 Answers
SOURCE: electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Posted on Jan 12, 2009
SOURCE: Oil furnace fan on all the time
who cares
Posted on Feb 06, 2009
clyde2j2
  • 137 Answers
SOURCE: Dayton Furnace - Pilot Light Goes Out but Fan keeps running?
Pilot lighted furnaces have a thermocouple made from disasimilar metals that when heated create electricity to actuate a relay that alows the gas to flow to the furnace.
When the thermocouple gets coated with carbon from the pilot lights constant burning it acts as an insulator and keeps the thermocouple from getting enough heat to generate electricity, a very good safety factor.
What you have to do is locate the thermocouple it should be located over the pilot light, you will see a gray substance around the thermocouple it will be hard like cement, take a knife and scrape away as much of the gray material as possible then sand the themocouple with a medium sandpaper until it shines, use one of you wifes emery boards, this should solve your problem.
Posted on Feb 24, 2009
  • 80 Answers
SOURCE: heater motor,fan making noise
Check to see if something is in the fan blades that is throwing it off balance. Also check the belt to see if it is ready to break.
Posted on Oct 02, 2009
  • 6 Answers
SOURCE: Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
Posted on May 17, 2010
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
HEATER FAN
If it was the thermostat it would not light up it sounds like it the high leval over heat not working or snapaction as they are called try jumping them out 1 at a time there are two .
Mar 30, 2012 | Dayton Heating & Cooling
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
Pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
May 30, 2010 | Heating & Cooling
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
