Question about Epson Stylus CX6600 All-In-One InkJet Printer
My Epson Styluss CX6600 won't charge
I have an Epson Srylus CX6600 Printer and when I turn it on I get an error message that states Error-Check Documentation. Then you may have to call service. The carriage where the Printer Cartridges sit will not move therefore, the printer will not charge.
  • 29 Answers
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
Posted on Sep 09, 2007
SOURCE:
Epson workforce 520 error: won't do anything.
Great job, yup there are sensors and switches that need to be triggered if they are not errors will be thrown.
Jul 09, 2012 | Epson Workforce 520 Printer
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Espon 320 stuck with service required error message.
There is no button pressing sequence for this printer Epson got wise to that one.However check this out for a resolution.
http://www.wasteink.co.uk/epson-ipr-reset/
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer error
follow the link for downloads, faqs,troubleshooting, documents and manuals.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664
Mark
Apr 10, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson cx6600
If you are using a cartride that has been refilled it may just need recharged. I purchase my cartridges off Ebay and some will not charge, so I just use a small devise, which you can purchase off Ebay, that allows you to reset the cartridge. IF a cartridge does not charge it will not work.
Aug 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
plz go to printer setting & clean durme
Mar 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
CX6600 error message
I suspect that a bit of gum may have traveled elsewhere into the printers internals. I'm sorry I can't be more helpful.
Just turning the printer off, pausing for 30 seconds, then turning it back on should reset it, but I'm sure you have already tried that.
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Cx6600
does it state call for servicing if so i have servicing software for all epson even new ones get back to me thanks
Nov 16, 2007 | Epson Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
