Question about Fujitsu LifeBook LH530 Notebook
Battery charging problem
My lifebook is not charging. The light is not dispalay. How to solution.
I have a brand new Fujitsu Lifebook AH512 laptop, have not been able to charge the battery at all, plugged in, not charging, what should I do?
If it's brand new take it back to where you bought it from and tell them. Don't try to fix it within the 12 month warranty - that's what it's there for!
Aug 25, 2013 | Fujitsu Siemens Lifebook C2230 Notebook
All lights come on my balckberry but my screen stays black
it because ur dispalay is damaged u have to change ur display
Feb 11, 2013 | RIM BlackBerry Bold 9900 Cell Phone
Why is it that my fujitsu lifebook LH531 battery indicator does not light up when it is charging but turned off?
Maybe you have not powered down your system and it is running on the battery? If it doesn't light up, how do you know it is charging? Have you checked it in control panel to see it charging?
Mar 19, 2012 | Intel Computers & Internet
S6010 will not charge battery and will not work on power lead
Are you seeing the battery or power light on the laptop go on when the ac adapter is connected? If not, it may be the ac adapter, or usually the charging port. I have had to change charging ports many times. But if you get no lights, it needs either a new charger, and if that doesn't change anything, it needs repair.
Dec 16, 2009 | Fujitsu Siemens LifeBook S-6120D Notebook
I have a fujitsu lifebook that will not charge my battery. I replaced the ac adapter, and i replaced the battery and continue to have the problem
Bad power circuit on the motherboard. Usually part of the motherboard and thus would require motherboard replacement to fix the problem.
Nov 13, 2009 | Fujitsu LifeBook A6020 PC Notebook
Not used for 1year will not charge up
It is possible that the battery of your Tablet is dead, Still you can try to connect the Tablet PC Directly with the AC adapter.
For you reference you can download the Manual From the following link
http://www.retrevo.com/d/df/P1510D_06SPR_USERSGUIDE.PDF?doc=9388c66467ea4385d3e5c4b5df5cbd28&ts=1254481117154
Oct 02, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
Fujitsu LIFEBOOK C1020 power problem
or a bfoken powr jack.I replaced mine recently for £4.00 and took approx 2 hours.
Jun 16, 2008 | Fujitsu Lifebook C1020 Notebook
Fujitsu LifeBook LH530 Notebook Logo
15 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
