Question about Intel Computers & Internet
Thermal trip the system is automatic shut down
    Brigadier General:
  • Intel Master
  • 3,400 Answers
A MOTHERBOARD ARE SHUTTING DOWN THEN IT OVER HEATS.YOU SHOULD CHECK THE THERMAL PASTE,THE FANS.
AND LET NOT GET TO HOT IN THE CHASSI YOU MUST SE TO CIRCULATE THE AIR
Posted on Jul 10, 2013
Why won't it start?
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
Sep 24, 2015 | Heating & Cooling
Why won't it start?
I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
2277HS
More than likely it went out on the thermal protection devise in the washer, most automatically reset after the motor cools down. Some are mounted at the rear of the washer.
May 12, 2014 | LG WM Washing Machines
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
I charge the barbie 12 volt jeep and get nothing. i also got two 6 volt batteries and wired them in series bypassing the original batteries but still nothing,are these fused?
I know you are technically strong to do the bypassing part. But assumption is to do with fuse.
Your Power Wheels® 12 volt battery is equipped with a built-in thermal fuse. The thermal fuse is
a self-resetting safety device which automatically "trips" and shuts down operation of the vehicle if the vehicle is overloaded or the driving conditions too severe. Once a fuse has "tripped", remove your foot from the pedal and wait approximately 25 seconds before operating the vehicle again. To avoid repeated automatic shut-downs, avoid severe driving conditions.
better call up Fisher price, and lay back with free mind.
May 06, 2011 | Fisher Price Power Wheels Barbie Jeep
Brand new dryer keeps shutting off. not tripping my breakers I don';t understand
There is a thermal cutoff switch in all hairdryers. If you by accident block the air intake or the filter is dirty, then the heat from the nichrome wire is not sufficiently cooled to keep the thermal switch from tripping. After the dryer cools down then the thermal switch resets and allows operation. Be sure the air flow into the dryer is not obstructed
Mar 25, 2011 | Rusk W8less 2000 watt dryer
My three year old dryer stopped heating. I replaced the thermostat and cut off thermal part. Then discovered the element was broken, so replaced it. This worked for ONE load. If the exhaust is kinked...
This will cause the dryer to shut-off on a thermal overload yes you said you cut off the thermal part and did you wire the wires together to complete the switch? There is another thermal switch sometimes down near the exhaust blower that could be tripping and shutting the dryer off.
Jan 21, 2010 | Kenmore 62882 Electric Dryer
Over heats and shuts off, wont start again untill it cools off. can maybe vacuum one room before overheating. cyclone tubes are all clean, all hoses & lines are clear. this vacuum is fairly new, not...
The electric motor has a thermal switch and is self-resetting so there is no re-set switch. Make sure the air filter for the exhaust is clean. Also make sure that the height adjustment is not too low causing strain on the motor. Always bring the height down to where the brushes just make contact with the carpet. It is possible that the thermal safety switch is tripping due to a bad switch. In that case I would contact Drit Devil if it is still under warranty.
Nov 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Jan 04, 2009 | Everex StepNote XT5000T Notebook
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
