Print shop 23 acdsee 3.1 errors
Advanced photo editor has unrecoverable plug=in error every time you try to pull image into that app of printshop... how do I fix this?
SOURCE: adobe photoshop 7.0 unexpected and unrecoverable error
sersxs
sers
ser
Posted on Nov 29, 2008
  • 256 Answers
SOURCE: I have a dell with Vista. Photo Shop 6.0 Editor will not open,
Find the Photo shop 6 program on your computer and RIGHT click on it. Choose properties. In the next window, click the "Compatability" tab. In theis window, CHECK "Run this program in compatability mode for:" and choose one of the operating systems from the drop down choices below. If this does not work, you may have to upgrade Photo Shop.
Posted on Jun 14, 2009
  • 50 Answers
SOURCE: I get an error 1305
Problem
Error 1305 or 1304
Solution
The Print Shop® 23 Error 1305... When attempting to install The Print Shop® 23, an error that includes the message "Error 1305..." or "Error 1304..." appears. A conflict during the installation may cause this issue. Completing a clean installation of the program will help to prevent conflicts that can occur. The remainder of this note describes the procedure. Complete the steps below to reduce conflicts during the installation.
Clean the CD or DVD
  1. Place a small amount of nonabrasive, liquid soap on the shiny side of the CD or DVD.
  2. Using your fingertips and warm water, gently rub the soap on the disc in a circular motion.
  3. Rinse the disc thoroughly and dry it using a clean, soft T-shirt or lint-free towel. Do not use paper towels or tissue paper.
  4. Install the program.
NOTE: If the error message reappears, I don't know an another massage.
I hope it works for you
Posted on Aug 25, 2009
SOURCE: LICENSE CODE FOR ACDSee Photo manager 2009
i want to acdsee licence code
Posted on Oct 23, 2009
vanherringto
  • 1738 Answers
SOURCE: Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Posted on Feb 04, 2010
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Uninstalled printshop 23 and am having problems re-installing. The installation process stops half-way through the process.
Hi Sharon
Had a quick look on the support page for this product and found the instructions, have a look here
Andrew Wright
Feb 21, 2012 | Encore The Print Shop 23 Deluxe Full...
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
Aug 11, 2009 | Encore The Print Shop 23 Deluxe Full...
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Saving in Advanced Photo Editor
it save in the printshop folder. look under the porgram file on your c drive.
do a file save in pirntshop, it will tell you where the file being saved. and also that is where you can change where you wan tthe file to be saved.
Jul 09, 2008 | Broderbund PrintShop Pro Publisher Deluxe...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
