Question about Refrigerators
Lg Fridge Model GR-L227STG
How do I get the darn cover off to change the light globe inside fridge at the top, not the bottom
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
MNTECH
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Hi my name is Anne Have just bought second hand fridge about a month ago the model is a LG GR-5512GC. Ihave just noticed its leeking,wateris sitting under crisper bottom of fridge is their a way it can be...
clean out the drain hole with neat clorine bleach,then check door seals fit flush to frame,make sure you cover all food with clingfilm to cut down on condensation..
Aug 25, 2010 | LG Refrigerators
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Apr 11, 2009 | LG LFC21760 Bottom Freezer French Door...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
