Question about Toshiba Computers & Internet
U torrent has put a message "windows ran out of memory"
U Torrent has put a message on my screen "Windows ran out of memory Unable to allocate 77312 bytes Please close some applications and press ok" I have tried to do this, but when I click on my utorrent it goes off and so cannot close anything
Pyrhyc
  • 2028 Answers
SOURCE: Windows Vista crash/hang in Dell Inspirion 1525
Disable the turbo memroy driver and see if it will let you go onlin, if so download the driver or updated driver (if any), then unistall and reinstall it. If it won't allow you to do this, then try a system repair with your recovery or operating system disc.
Posted on Jul 23, 2008
frcs68
  • 1605 Answers
SOURCE: i am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Posted on Nov 14, 2008
rockitman187
  • 2559 Answers
SOURCE: Bad Pool Caller message??
BAD_POOL_CALLER is a stop error message that is caused because of problems with the memory management.
There is a list of more than thirty such causes that can give you this error message. If the stop error is consistent every time the system is rebooted, the following method will be effective in solving the problem:
* The hardware and RAM should be checked initially.
* Boot the system once again using the OS setup CD, or use a boot setup that has a GUI like BartPE.
* With RunScanner it is possible to use a memory test tool.
* Select a single account
* If all the accounts open then the system registry hive might be the problem.
* Locate the hive damaged and rename it, do not delete it.
* Create another hive from the backup or from the restore point.
* Initially uses the latest one and keep checking the restore points that come later.
* Avoiding harvesting any replacement hives from the hard drive booted Windows.
* After which compare the hives for differences.
This is one of the ways of fixing BAD_POOL_CALLER errors. Another method is to reinstall the OS but occasionally shows a disk read error or an error on the same lines. Switching the computer off for a minute or more and then switching it on can solve it since the error is only a slight glitch in the system operation.
The BAD_POOL_CALLER is seen for the first time after installing a hardware or software it is recommended that the computer be restarted. If it doesn’t solve the problem, the installation of the hardware or software should be checked for corrections. If the problem persists the installed hardware and software should be disabled, and the BIOS memory options like caching or shadowing should be disabled too.
The safe mode can be used as well to remove or stop components.
To enable the safe mode just press F8 when the machine is being restarted and select it from the Advance Startup options and correct the problem. The installation of the graphics card is another reason the BAD_POOL_CALLER error shows up. A simple reinstallation of the driver can solve the problem.
Microsoft has also acknowledged that the BAD_POOL_CALLER Stop 0xC2 error pops up when trying to print a document that contains a corrupt font.
A hot fix is available at www.support.microsoft.com
Posted on Jan 10, 2009
SOURCE: I have a dell latitude es400 and it keeps giving
You can reinstall the entire operative system with the CD that comes with your laptop, or with the restoration partition. See user's manual. This is the best way to fix error in a PC. Before restore the OS, backup your personal data.
Posted on May 14, 2009
SOURCE: Dell Inspiron 1525 Blue screen & windows error messages/reformat
If the ram passed memtest then the problems are likely to by corrupt system files. rather than do a complete reinstall and have to worry about backing up the data try ReImage. They c will remotely fix the system files, leaving your data intact
ReImage
Posted on Jul 18, 2009
in the tools of your browser you can add more memory page for to work in the internet. do it.
God bless you
Jul 10, 2013 | Toshiba Computers & Internet
I have a Asus eee 1005HA running Windows XP. When I try to boot, I get an error message saying "file missing or corrupt \windows\system32\config\system You can attempt to repair this file by starting...
http://thepiratebay.org/torrent/5199210/WINDOWS_XP_PRO_32-BIT_SP3_ISO_ACTIVATED_GENUINE
download the bootable image file here, use torrent downloader to download
after download burn iso file (use burn image file) to cd, and you get windows cd installer
and you can use this cd to repair your computer
i hope this helpful
thank you for using fixya
Feb 05, 2011 | Computers & Internet
My acer aspire 5515 wont load windows vista it just gives me a blank screen
go here: http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
download the torrent let the file the torrent wants to download download burn the image to a disc and put it in your CD drive and let it run and do what it tells you if it does find a problem depending on what it is it will fix the issue
Dec 11, 2010 | Computers & Internet
My computer ask for genuine microsoft software
Hi, Try Referring this link. http://windows-xp-genuine-crack.blogspot.com/
or This is a torrent link and so you download bit torrent software and install it from www.bittorrent.com
Download the software in the below link and install it to make your windows xp genuine if your os is not original 1)Go to the below link http://thepiratebay.org/torrent/3550335/Make_Windows_XP_Genuine_in_5_seconds._No_more_WGA_Cra cks.
2)Click download this torrent which will be written in green colour 3)open the downloaded torrent file and the software to make your xp genuine will be downloaded OR To remove and byepass this message: To remove and to by pass this message there are two options: First Method:
1) Lauch Windows Task Manager by pressing cltr + Alt + Del. 2) End wgatray.exe process in Task Manager. 3) Restart Windows XP in Safe Mode. 4) Delete WgaTray.exe from c:\Windows\System32. 5) Delete WgaTray.exe from c:\Windows\System32\dllcache. 6) Lauch RegEdit. 7) Browse to the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\Notify
8) Delete the folder 'WgaLogon' and all its contents 9) Reboot Windows XP.
Nov 29, 2010 | Microsoft Windows XP Professional for PC
Where we can download free Windows Vista Ultimate
There is p2p aplication called bit torrent that you can download from www.bittorrent.com
and install it afterwards got to mininova.org or piratebay.org and search for the required software
when the listing comes click on download which will actually download the ftp component or torrent **
and now select ok in the popup window .
you may forcestart the downloading and allocate high bandwidth
Thanks and Regards
Fixya is proud to answer your query
May 12, 2009 | Microsoft Windows Vista Ultimate Edition
How can i download new super mario bros.
Just go to www.mininova.org it is a Torrent Website
Torrent is nothing but a link. in search box put super mario bros
u get lot of links select the link which has more seeds and peers
click on that u will get a window in which download torrent option in that download torrent ok.
but
Always u must check for the details and comments in the same window before downloading ok
Before going to www.mininova.org website u should download torrent software i.e,example :Bit comet,Bit lord,U torrent,Bit torrent
these are all the softwares
according to my experience bit comet is best just search in google u will get it and install it after wards go to www.mininova.org website download the torrent and open bit comet software in which ADD the torrent link which u downloaded from www.mininova.org and u r download starts finally u r downloaded file will be stored in C:My Downloads by default.
Like this u can download Games,Movies,Music,Softwares etc...........
Mar 06, 2009 | Microsoft Windows XP Professional for PC
Utorrent. the port problem had been solved. but the connection is still yellow
please check if the port allocated for u-torrent is port-forwarded properly..also check you have assinged a unique port number for u-torrent program..go to options tab in u-torrent and speed guide options in it and check the assinged port number!..or u can visit www.port-forward.com to port forward for the u-torrent!..thank you !!..
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
323 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
