Question about Electronics - Others
There was a problem starting ~$wq.usbdrv problem in usb pendrive
Hipstreet tablets
Ahh , You have a nice problem on hand that made me almost want to toss this tablet out .
There is a few tricks to get your Tablet back , You require a few things
-A usb cable to connect to computer
-Internet connectivity
Now Lets start by putting the tablet in Android recover mode .
1. Connect the tablet to the USB port on the Computer .
2. Press and hold the power button and the Big button on the tablet , Keep pressing it until the logo of the android gut with his gut open shows up .
3. It is possible to perform a reset using the ADB (Android Debug Bridge)
I did mine on Windows XP , (Does your tablet install correctly in the Device manager? )
If so That is great news , You may goto step 5
If not Goto step 4 :
Step 4: Getting the Chinese driver equivalent for your tablet .
Get the drivers for the Ainol 7" Auror tablet (or equivalent )
Now Before the driver will work with your device (you can try to install it but it will give you an INF error)
You must edit the file (.INF) to match your USB id of the tablet
(At the bottom of the file change the STRINGS section to the device codes of your tablet ) (found by right clicking the Unknown device in the device manager . the (VID_1f3a_PID_efe8) is the HARDWARE ID and the
[Strings]
USBDRV="USB Devices"
USB\VID_1f3a&PID_efe8.DeviceDesc="USBDevice(VID_1f3a_PID_efe8)"
YOUR STRINGS:
USB\<YOURDEVICEID>.DeviceDesc=USBDevice(<YOURDEVICEID>)"
Step 5:
Get the Recovery tool from here
https://spideroak.com/share/KNQW243VNZTUGYLMNRUXG5DP/manta_mid08/home/willing/Android/Builds/Manta/Recovery/CWM_Recovery_Manta_MID08_windows_install.zip
This will give you a suite of tools to restore your device to factory reset
Use it to install the recovery partition , and then reboot your device in recovery mode , Then use the Vol + and - buttons to navigate and power button to Enter .
Good Luck
Jan 03, 2014 | Hipstreet Tablets & eReaders
I have a problem regarding my pc. i have an usb pendrive and i have created windows 7 usb pendrive when i boot my pc through this it is not booting normally starting up windows. i have changed first boot...
You need to make sure that the pendrive has a bootable copy of your operating system or it won't work. The way you seem to be using it is unusual. you would have to have installed the OS onto your pendrive instead of a hard drive.
Jan 30, 2013 | Computers & Internet
I have a DT 100 8GB usb pendrive I put my pendrive in USB and copy pictures from my PC to pendrive after I can see my pictures on pendrive but when I go to properties I can see that I am using some space...
I would tick in one box automatically fix files then return after it has repaired then tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start or you might tick one box then return after its finished the first repair the tick the second box
hope this helps don
Mar 01, 2011 | Computers & Internet
Error opening
I have a kingston DT10 pendrive. When you plug in the pendrive to any computer, it say the pendrive needs to format. When you click format, then it say that windows cannot format the disk. I've try large number of software such as HD Guru Low level format but it's also useless. The problems start when a virus attacking my pendrive then suddenly hidding all my files. It's not a big deal to me to open it using up level button on the winrar system. But, the problem starts when im deleting a strange folder named 3hkgj..... something like that.
Dec 11, 2010 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Usb pendrive not shown in my computer. i am using win 7
insert ur pendrive in pc then start your pc .........may be ur pendrive will show
Oct 16, 2010 | Electronics - Others
My pendrive show unrecognized in my pc. what should i do
Insert pendrive firmly 1st then restart ur pc ; inbuilt pendrive drivers will be installed after restart of pc your work refresh ur comptuer about 5 times till the drivers get installed goto "mu computer" ur pendrive icon will be displayed double click n start using repeat the above process if it doesnt work 1st time
Sep 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Dell laptop gets hanged when the usb pendrive is inserted.
it could be that u have such little ram that when windows recognizes the pendrive its already busy but windows does this thing called auto play on usb devices like cameras memory card readers even flash drives just try leaning up your current windows install by removing startup programs through msconfig and just getting rid off all the spam delete your internet history thats hdd space that could be used elsewhere just stuff of that sort
Aug 10, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Usb problem
There is no repair options for transcend pendrives.You can try formatting them, by right clicking on the device driver and selecting format option.Press start and the pendrive is formatted.Also the data in the pendrive will be deleted.Generally if the device is not being detected, then the pendrive can be claimed for a lifetime warranty.
Jan 19, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Where can i get USB cable and charger for WQ N95 ?
first you should try finding it on ebay or criags list(they have the best deals)... if that doesent work then try speacial ordering from the makers website ex. garmin or tomtom
Sep 10, 2008 | GPS
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Electronics - Others Logo
62 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
