Question about Zanussi IZ161S Front Load Washer
Electrolux wh1092 start ew1000i - Zanussi IZ161S Front Load Washer
Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
So, could be: main electronic PCB, display board or wiring.
Dado
Dec 13, 2014 | Electrolux Washing Machines
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
Electrolux washer dryer ewd 1409 start and pause light keeps flashing
That is a generic error code - please reset the unit at the household circuit breaker for about 10-15 minutes, and then retry the unit. No difference - please consult a professional.
Aug 22, 2012 | Electrolux EW1000i Front Load Washer
Where can I contact the nearest technician? We are in Bulacan area.
Hello
You can use this service locator form Electrolux:
Electrolux Service
Then choose Central Luzon and then choose Bulacan.
Thanks for using Fixya!
Rate my answer if this helped you.
Sep 12, 2011 | Electrolux EW1000i Front Load Washer
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
The start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Electrolux EW1000i Front Load Washer
Error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
Oct 15, 2008 | Electrolux EW1000i Front Load Washer
Zanussi IZ161S Front Load Washer Logo
14 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
