Question about Avanti Fitness AT480 Treadmill
My avanti AT 480 started ok then came up with message error 4 - over current
Have checked leads all ok, turned on and off a few times, starts off for a few seconds then stops with same message appearing - error 4 - over current. please advise what to do next. cheers! rod boyce rwb@brenclosures.com.au or rwboyce2651@gmail.com
2 Suggested Answers
SOURCE: Avanti AT 480 treasdmill error
Lubricate your deck, run it at full speed for 10 minutes.. easy fix.
Posted on Oct 10, 2010
Error 4 on my avanti 380
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill error codes
Mar 13, 2016 | Avanti Fitness AT380 Treadmill
Engine turned over but wouldn't start, now won't even turn over
check that battery by having a load test done as you may have a dead cell.
Mar 23, 2014 | 1996 Chevrolet Blazer
Suspect upper panel faultr,shows En9 in r/hand[speed]window at start up
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
Apr 03, 2013 | Avanti Fitness AT380 Treadmill
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Avanti AT 480 treasdmill error code - over current
Oct 02, 2010 | Avanti Fitness AT480 Treadmill
I have an Avanti outdoor refrigerator. It's about
Try to place on flat ground surface, u can balance its weight. Check compressor fan if its making noise.
Nov 05, 2009 | Avanti BCA5102 Stainless Steel Compact...
Some times it will not start. turn the key and dash lights go out and it dont turn over or anything
Your problem could be a few things ..1 Battery flat or low down to 10 volts or lower if when you turn the key the ign lights go out. 2 check earth lead from battery to engine block and from block to body for earth lead(Black lead) 3 Starter motor or RED feed
lead from battery term if all ok then some times wont start ,open the bonnet and turn the key for 5sec and if either term is hot thats the dirty one..
Sep 30, 2009 | 2000 Chevrolet Monte Carlo
Check the Color Toner Cartridge
Try to take out all the color toner.. And start the machine... If machine can startup properly, it will ask u to insert toner one by one...
PS: What is your current print counter?
Apr 17, 2009 | Toshiba Office Equipment & Supplies
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Outlook xp keeps shutting down
The first thing I would check is your current disk space on your main drive, C:\ I assume. Many times I get that error when in reality it's the total disk space that is the problem.
If that is not the problem and you have at least a few gigs (if not, hopefully, much more) free still, check what's running. Do you by chance have an add-in to Outlook that is causing an issue? You can check and try to disable your add-ins by going (in your Inbox) to Tools > Options > Other (tab) > Advanced Options > Add In Manager and also COM Add Ins. Look for non-Microsoft add-ins.
You can disable things from here and see if that helps. If you can tell the exact error message that it gives you and/or the DLL file that is causing trouble, that may lead to a more definite solution. You can also try starting Outlook in Safe Mode by going to Start > Run > and type (without quotes) "outlook.exe /safe" and click OK. See if your problem still happens in safe mode and we can troubleshoot more from there if it is not fixed by this point.
Jan 14, 2008 | Microsoft Office Standard for PC
Avanti Fitness AT480 Treadmill Logo
22 people viewed this question
Top Avanti Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Bill Boyd
Are you an Avanti Exercise and Fitnes Expert? Answer questions, earn points and help others
