Question about Nokia C5 Cell Phone
Imei gsm rpl unlock - Nokia C5 Cell Phone
    Scholar:
    New Friend:
  • 166 Answers
Do you want to unlock NOKIA C5 from carrier lock?This GSM RPL unlock is software.You need to be a professional to use this and unlock your Nokia C5.It may damage your phone if you don't how to use this.So better use unlock code to unlock Nokia C5 from carrier lock.Get unlock code from the site Prounlocking.com and unlock it easily.
Posted on Jul 11, 2013
Unlock gsm network code mobile imei
You can get the GSM network unlock code for Samsung Star GT-S5230 from Unlock-Zone.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
May 09, 2013 | Samsung Star GT-S5230 Unlocked Phone GT...
Tip
How To Remove a Restart Problem when Phone Imei is oK but Phone goes on to...
Inthis case first try to solve this problem by only Write Full Modified (Without308 Field) PM With
SX4 Auth.Use SX4 and when it done Successfully then immediately Write supportedfull modified PM to the phone and check phone without MMC, problem is fixed ornot, if not then Full Flash and after that Write PM with SX4, or try to solve
by Downgrading.Oftenly Restart problem is removed by only do File System Formatand Factory Default. (Check
phone without MMC) Otherwise there is only one way is left to Repair it with Software and that
is Erase Flash (Rap), to start the Erasing Procedure,
Follow thisgiven below Method:
Before StartErasing Flash, Save your both backup PM 308 and RPL backup (CRT 308 and CRT
BKP)If you are going to do erase newer BB5 + (Plus) Phone then you must Savealso Full PM 0 to 400
Backup, coz you will need it for restore the orignal field 308, this is reallyfast easy and perfect
way to restore the PM 308 Field, otherwise you may need to buy an new RPL.So be careful. . .
Now we are ready to do erase.SelectUNI_rapido.bin in Mcu Part and click to Flash
and for MT Select uni_rap.bin as MCU.
when phone will fully erased then Phone Imei will be: 12345610654321, SP Areawill damaged
and CMT Flash Data will shown: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Now Full flash with any Firmwarever but selected firmware should be not too Old or too New,
coz we may need it in another case.After Flash when phone will turn On, youwill get
damaged IMEI: 12345610654321 and Courpted SP Area:
PROVIDER KEY: 0000000000000000, Provider: Unknown provide
Now first of all you have to Restore the Orignal backup of PM 308, in case whenyou are unable
to restore the PM 308 backup then flash again with same FW when you were takebackup.
When it flash successfully then plz stay a min and write it (PM 308) back tothe phone, now
Disconnect phone, connect it again and see SL Zone is Repaired or Not.
(It should be repair now), if not then flash again with same FW and restore thePM 308 backup.
But if you have Full PM 0-400 backup then no need to Flash again, just Write it(Full PM 0-400
backup) back to the phone without SX4,when it done successfully then removecable to the box,
replug cable and get info you will see SP Area is Repaired now, if not then itwill be repair after
writing RPL backup.
After successfully restore the PM 308 backup phone will on ContactService/Retailers or full
working phone with damaged Imei. In this condition when phone has damaged Imei:
12345610654321 you can write full modified PM
(without 308 field) without using SX4, coz phone has not certificate (IMEI),therefor no need to
use SX4.Now we have to Restore RPL backup. If you are using JAF then Click onCRT Tool, now you will
see BB5 Certificate Tool Window
tick on Write RPL Option and also mark onPlain RPL box, now Select your RPL backup and
click on Write RPL button.Get info now and see Imei is restored succcessfullyor not phone
should be on Contact Service/Retailer or fully working. . .
But if you are failed to restore the RPL backup, i mean phone Imei is stilldamage and phone
show only Nokia and then shut Off in case now you Write blank_rpl and Flashagain with Latest Firm Ware.
When it (flash process) done successfully then write RPL backup, get Info andsee Imei is back or
not, it (Imei) should back now, and your Phone will on ContactService/Retailer, if Not and you
got dead phone Please follow again all above erasing method.
Finally use SX4 and Write PM Field [1] and [309] (or full pm as you wish), nowwe have done all
abt Software.I think That's all. . . abt BB5 Repair with Erasing Method and wehave confirmed
now, phone has Software Problem or not.
on Apr 26, 2011 | Cell Phones
N1600is sim not valid imei????????4
If you have MXKEY follow the instruction,1.OPen MXkey 2.bus check Go to Service >>IMEI and Security>>IMEI Rebuilt >>Read ASK >>Backup RPL >>Write RPL >>and click to From backup >> Restore IMEI. But remember the location, where did you save the backup.Thanks Good luck
Aug 19, 2011 | Nokia 1600 Cellular Phone
Nokia 1616 imei ?????????0000
The phone will not recognized any simcard you inserted and also can not be unlock due to a corrupted RPL. IMEI or serial numbers is damage and need to a patch file to be able to retrieve the serial. and this will be possible if using a gsm gadget and only mobile service center have this tool.
Jun 22, 2011 | Nokia 1616 Cell Phone
No rpl and imei 1234567891
Here's the fastest way to unlock your phone... just visit this site http://www.imeiunlockcode.com you can purchase an IMEI unlock code for your Blackberry, HTC, LG, Motorola, Samsung or any other GSM phone and unlock it in seconds. its 100% safe (no loss of data or contacts). All you need is type the IMEI unlock code and your phone is 100% SIM lock free. It really works. ;-)
Jan 25, 2011 | Nokia 3110 Cellular Phone
Pls.help me ineed imei code for my blackberry 9000 ntt docomo japan my imei#351845.03.454505.6 for unlocking thank you very much aljo garc.
Hi
You may call to your network provider for an unlock code, usually it takes 10-15 days to get the code. You can also buy the ntt docomo Blackberry 9000 unlock code from third parties. They usually give you the code in minutes. You can check this Blackberry Unlock Code site, they will provide you an accurate code for the lowest price.
Thanks
Oct 29, 2010 | Cell Phones
Hello! my cell nokia n73 imei number is 12345..... what is the solustion
Dear Brother,
  • RPL file can solve this problem...
Sometimes if your Phone Flashing Unexpectedly stopped and there may be Chance to be imei like 12345.So you need to Flah it by Another version...This will only make re Storing OF YOUR imei. RPL file can only Write IMEI to the Phone and will Solve the Problem.
  • You need to write RPL file
  • OR do flashing with another version(this will only work in the above some case)
Go for RPL writing..Your Problem Solved...
Hope this Text Helped you.... Do Rate ME... Thanks For Using FixYa
Apr 06, 2010 | Nokia N73 Cellular Phone
Invalid sim problem
Hi brother this is problem of your handset imei use ask 2 rpl service.
Feb 20, 2010 | Nokia 1100
How to unlock vodafone 716
I have a vodafone 716 mobile and the IMEI no is 359009011142336. plz send me a code to unlock the sim
Apr 12, 2008 | Nokia 6300 Cellular Phone
Display SIM not Valid
box named universal box (UB) can rebuilt ur phones IMEI
Jan 09, 2008 | Nokia 1600 Cellular Phone
Nokia C5 Cell Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
