Question about Sony HVR-1500 HDV VCR
21-1C1 Failed to complete the reel position movement within the specified time
  • 53 Answers
Error 21-1C1 Failed to complete the reel position movement within the Cassette tape in specified time. will be ejected.
Posted on Jul 18, 2013
What does FO2 MEAN ON PANASONIC MOVIE CAMERA
. Error Codes Panasonic JVC Description F01 . No Take-Up reel rotation F02 E03 No Supply Reel rotation F03 E02 Mechanism has not unloaded to the Eject position F04 E01 Mechanism has not fully loaded up to the stop position F05 E04 Rotation of the video head has stalled or too fast . E06 Tape drive motor is not rotating or stalled F31 . Data Transmission error F51 . Focus drive motor is not functioning, no focus. Color F52 . Zoom drive motor is not functioning, no zoom U10 . Dew Sensor has detected condensation or failed U11 . Video Heads have been detected as clogged failed
Nov 14, 2014 | Cameras
Tip
ERROR codes Canon 8580
Canon 8580 E000 The temperature of the upper fixing roller has not increased above the specified level 90 seconds after switching power on. The temperature of the upper fixing roller does not reach 150 C within 8 minutes after switching power ON. The temperature of the upper fixing roller does not reach 180 C within 5 minutes of reaching 150 C. The temperature of the upper fixing roller drops below 50 C during STANDBY. E001 The temperature of the upper fixing roller exceeds 250 C. E005 The length of fixing assembly cleaning belt wound on the take-up reel exceeds the specified length. E010 When two or more clock pulses are not inputted for a period of 2 seconds after a MAIN MOTOR DRIVE command is generated. E011 When excessive current is detected by the fault detection circuit of the DC driver PCB. When excessive current is detected by the fault detection circuit of the duplexing unit driver PCB. When excessive current is detected by the fault detection circuit of the scanner motor driver PCB. E020 When a toner out signal (TSP) is emitted from the developing assembly for a total of at least two minutes. E050 When the HOLDING TRAY HOME POSITION signal (THP) is not generated within 4 seconds from the beginning of HOLDING TRAY MOTOR DRIVE command (TMDP1,2) When the HOLDING TRAY HOME POSITION signal (THP) is generated for at least one second while the HOLDING TRAY MOTOR DRIVE command (TMDSP1,2) is being generated. E203 When two or more clock pulses are not inputted from the SCANNER MOTOR DRIVE command is being generated. E210 When the LENS HOME POSITION signal (LHP) is not generated within 4.8 seconds after the power switch or door switch goes ON. When the LENS HOME POSITION signal (LHP) is generated for 2 seconds or more. E243 When an abnormally in communication occurs between the microprocessors on the DC controller PCB and those on the control panel PCB. E400 When an abnormality in communication occurs between the DC controller PCB detect RDF controller PCB. E401 When a flag mounted on the pick-up roller HOME position sensor (S3), it indicates that M1 is turning. S3 should go ON and OFF two or more times in one second. E402 The number of pulses in a 200 ms period is too low. E403 When the number of feed motor clock pulses in a 200 ms period is less than the correct value. E411 When the sensor output is greater than 2.3V when there is paper. E500 When an abnormality in communication occurs between the DC controller PCB of sorter detect main controller PCB. E510 When there is no pulse output from the feed roller motor and when the first copy jams. E540 The lead can HOME position sensor does not go "OFF" within 0.5 second after the BIN MOTOR DRIVE signal (BMON) is output. E541 The lead can HOME position sensor does not go "ON" within 1.0 second after the lead cam position sensor goes "OFF".
on Jan 19, 2010 | Office Equipment & Supplies
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
E210
related to the exppossure system the lens does not return to itfs home position within the specified time fix its movemenet. expossure lens. The lens (camera) you must look for any-thin that might make its movement difficult in its rail. also check the sensor if properly positioned. and oil its path.
Aug 02, 2011 | Canon NP 6551 Black and White Copier
Won't turn on. I press the power on button and the lens won't come out. It's revealing an E18 code on the display.
E18 = ZOOM LENS ERROR
Movement of the lens barrel did not end
within the specified time.
caused by MAIN PCB ***’Y
Feb 04, 2010 | Canon PowerShot S400 / IXUS 400 Digital...
Change battery everything gone dead will not take land rover disc
Firstly, pop a new battery in the fob.
Now we can enter the EKA.
Close all the doors.
Turn the key in the driver door lock to the unlock position and hold there for at least 5 seconds until the alarm sounds once. Then return to centre - always ensure you return to centre and do not delay more than 10 seconds between turns, or hold in the position for more than 5 seconds or you will reset to the start. Turn to full extent of travel.
1st Digit turn to unlock the number of times specified.
2nd Digit turn to lock the number of times specified.
3rd Digit turn to unlock the number of times specified.
4th Digit turn to lock the number of times specified.
Finally turn to unlock once more. If it is correct a double bleep will sound (single bleep is incorrect code)
You now have a 5 minute delay - don't open any doors. The anti-theft indicator will continue flashing once every 2 seconds for the five minute period. When this goes out, open the door and start within 30secs.
After 3 failed attempts, the security system invokes a delay period of 10 mins during which the system will not accept any further attempts to enter a code.
Jan 18, 2010 | 2004 Land Rover Discovery
Auto off Unloading Lock I do not achieve that my chamber(camera) panasonic dvx100 expels the tape
When the movement of mechanical position does not completed
to move unloading direction within regular time.
must remove cas. cover and if tape is not slacked apply 4 volts on loading motor connector and the cas. will go out.This problem is not repairable by not authorized personnel.
Oct 22, 2009 | Panasonic AG-DVX100 Mini DV Digital...
I have the code for my 2002 land rover discovery i just dont know how to put it in, any ideas thanks
To enter the EKA:
Oct 19, 2009 | 2002 Land Rover Discovery Series II
Re-incert cassette
If your getting a reel error, then the chances are the reel assy is ok. Most likely the reel sensor is defective and must be replaced by a tech. A reel failure will result from the reel table not turning in a specified amount of time, so a motor not running, bad connections @ the main board or a defective tape can produce the same failure.
Mar 05, 2008 | Sony Hi8 CCD-TRV138 Camcorder
What do L.EMG and R.EMG mean and why do they prevent me from any activity with my camera?
Hello, The errors you are getting are "reel" errors. One or both of the tape reels are not turning during tape movement and the camera is shutting down to protect itself and your tape. In this model this problem is usually caused by the take up reel shaft being bent due to improper insertion of the cassette although this may not be the case. Please inspect both the takeup and supply tape reels and insure they are in correct alignment, if not, a gentle push to one side or the other will place them back in operating position. Good luck to you. Joe Weibel CustomElectronics.Org
Apr 22, 2007 | Samsung SCL901 Hi8mm Camcorder
Sony HVR-1500 HDV VCR Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
