Question about Linksys Computers & Internet
192 168.1.245 Cannot access; cannot reset. I have tried all the obvious solutions.
Samsung un40h5500af shows Smart TV screen but cannot access menus or change input sources.
Do a hard reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 11, 2016 | Samsung Televison & Video
Can't remember password...is there someway to reset it. Obviously can't get into/onto computer
Hi Sara,
You obviously have Internet access by a different means, just contact the manufacturer's customer support centre.
Aug 01, 2015 | ZEEPAD 9XN Dual-Core 1.5GHz 512MB 8GB 9"...
How to recover my password to Netflix without having to reset my password
Obviously the only way is to reset your password.
If you are trying to gain access to someone elses account, which it sounds like you are then this is not great is it?
Mar 15, 2015 | Computers & Internet
Dishwasher LG no lights no power
I am sure you tried the obvious (circuit breaker on)...but have you tried resetting the motherboard cpu. Sometimes a simple power off at fuse box...wait 1 minute and then power on can reset it. If this fails, the internal fuse has probably failed. If you are brave, open the inside of the door and access the board. Inspect for failed (cartridge) fuse and for any obvious signs of a burned component in the power-feed area. (PLEASE be sure that the power is removed from the dishwasher before attempting this!) If nothing obvious is found, call the LG service folks, tell them the problem and ask for a fix or a service technician recommendation. Depending on the age of the unit, it may be repaired under warranty.
Jim
Mar 11, 2014 | LG Dishwashers
My Sony Ericsson t700 has been having a "no access to network" problem. The ""no access to network" " is written where the operator should be, and you can't receive calls,...
Make sure of the obvious - WIFI is switched on and Aeroplane mode is switched off.
Power off your router for one minute and restart it.
Oct 26, 2017 | Cell Phones
I've forgotten my login password
You'll have to take it to a computer shop and they'll have to reset your computer. Hope this helps!?
Please rate solution - Thanks.
Apr 19, 2010 | Dell Inspiron 700M Notebook
How do you gain access to the "used ink tank" on the Canon i560?
Well Fay after much research, the best answers I've seen actually came from other experts on this website. The link below will take you to another Fixya page with several, very good solutions to the same problem you have. My personal favorite was soaking up waste ink from the pad with kleenex or some other absorbent material as you won't need to take apart your machine. You merely remove the ink cartridges and carriage to gain access to the pad/sponge that Canon calls it's waste tank. I do wish you well and hope you come back to let me know if you were able to fix your machine.
Greg
Fixya Waste Tank Solution for Canon Printers
Nov 08, 2009 | Canon BubbleJet i560 InkJet Printer
Digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Nov 18, 2007 | Canon ZR70MC Mini DV Digital Camcorder
NO IP or MAC displayed
Solution: IP of 0.0.0.0 means your DHCP server is not providing configuration settings to your network card. Reset router/access point by pressing the reset button with your finger, the tip of a pen, or a paper clip for at least 30 seconds. Try again! If this solution doesn't work, try turning off computer, turn off router/AP, and DSL/Cable modem. Turn on devices in reverse order. First power on modem, then router/AP, then computer. Connect to router/AP and see if it provides IP. If this solution doesn't work, your DHCP settings are not configured correctly. See router's manufacturer manual or visit their Web site.
Dec 28, 2005 | 3Com U.S. Robotics Wireless Turbo...
Computers & Internet Logo
499 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
