Question about Sony SLV-940HF VCR
SLV 940 HF
Tapes keep getting stuck. All commands are blocked and the it dispalay L H 22 M 11 S. mihai
  • xcnagar Jun 07, 2008
    I Have exactly the same problem. No plastic broken parts. The carriage mechanism seems to be a little bent. Where can I buy the part?
  • Anonymous Mar 15, 2014
    Tape Stuck in VCR SLV 940 HF
    Novelist:
    Champion:
  • 254 Answers
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Posted on Aug 27, 2007
SOURCE:
User manual Sony VHS SLV 940 HF
You may download a copy of the manual here.
Apr 08, 2013 | Televison & Video
Help SLV-900 has a screen that randomly flickers and wont play
Advice given has helped me to sort out this problem thanks
Mar 07, 2010 | Sony SLV-D100 DVD Player/VCR
Intermittent loss of video (mimicking dirty heads symptoms)
Control head dirty. That is where the tape counter picks up the frame pulses.
Jan 18, 2018 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SlV-SE730 VCR video inserted wrong way
Unplug the VCR.
Take the cover off by taking out the small screws on the sides and on the back that hold the cover on.
With the cover off you should be able to gently move the tape back out.
Things could be damaged......after the tape is out, you should try it first with a tape that could possibly be damaged during testing and do not touch anything inside while plugged in to power during testing with the cover off!
Now......if it is not a working VCR anymore......you are in luck.
There are garage sales every weekend...and almost every one has a VCR for almost nothing....some like new.....and boxes and boxes of tapes/movies for very little money too.
Sep 06, 2009 | Sony SLV-SE730 VHS VCR
The rubber roller fell off the pinch assembly sony slv 760 hf
On top of it there must be a white plastic cover to keep it in place.
Aug 04, 2009 | Sony SLV-778HF VHS VCR
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
324 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
