Question about Samsung LA22A450 22 in. LCD TV
I have sharp tv model 29v r230s after replace new flyback there's no picture comes out but there have a sound only white on the screen. can you help me please.
3 Suggested Answers
alpug
  • 1961 Answers
SOURCE: My samsung le40r73bd tv has developed a fault the
there is a problem on your inverter board and the cold cathode lamp.The inverter board is the supplying high voltage supply to the cold cathode lamp.This cold cathode lamp is the illuminating the screen in which the the picture will appear once cold cathode is lit.here is a link where you can buy the parts.. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
  2. http://s807.photobucket.com/home/budm/allalbums
:Good luck hope this helps you..
please rate my help
Posted on Jun 14, 2010
snakehead
  • 1074 Answers
SOURCE: I have a Samsung 50
Your tv horizontal section is faulty change the horizontal transistor.or the diode that is at the leg of the collector of the HOT.do other checks around the transistor cause it can be more than one component is faulty in that section.also make checks in the power there is a diode that feeds from the pout put of tv regulator that might be leaking or is open.
Posted on Sep 28, 2011
Flyback number of sharp tv model:21V-FP80M
gud pm,hi der sino po nakakaalam kung ako ang flyback no ng sharp model no. 21V-R230S
Aug 22, 2012 | Sharp Televison & Video
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
Jan 22, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cannot see the picture on my tv
This need an adjustment in flyback screen to make it higher so picture must seen.Open your TV go to the flyback there in the flyback body you can see a little rotary nab for "focus" and "screen"Just only adjust the screen a little until picture comes out.
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Sony Televison & Video
Sharp model 29V- FL250s
ac supply track check this ic ac pals track on resister 240k or470k &diode check this track
Jun 14, 2008 | Sharp 25R-S100 25" TV
Sharp v29j200s always blue on the screen
Sharps are known for bad tuners and cold solder joints.If you tap on tuner and picture comes back there is cold joints in tuner, If not most likley bad tuner. if the audio is there with blue screen it is the tuner definitly.good luck
thanks DOCTOR VIDEO
Mar 25, 2008 | Orion1934 19" TV
Sharp 20f640 focus problems
At the rear of the tv there may be two controls on the right hand side marked "screen" and "focus".If the set is newer,you will have to remove the cover and look to your right.You will see a dark object with a black or red wire coming out of it's top.That is your flyback transformer.On this you will find these two controls.Adjust your focus with the one so marked.Be careful to only adjust this control while you watch your picture clear.PROMPLY put the cover back.
Feb 10, 2008 | Sharp 20F640 20" TV
SHARP MODEL 27N-S100
Flyback part number RTRNF0033MEZZ
Nov 10, 2007 | Sharp 27N-S100 27" TV
I have sound but no opicture
When you replaced the flyback the new flyback is shipped with the screen and focus controls set at minimum. These are the 2 controls on the flyback itself. Turn the set on and let it warm up a minute, then slowly turn up the screen (bottom) control with a small flat-head screwdriver. When the picture is around normal brightness, adjust the focus (top) control until the picture is nice and sharp. Then, turn the brightness and contrast all the way down and set the screen control until you can just see the picture, just above the point where the picture vanishes. Reset the brightness and contrast settings and your picture will be back to perfect.
Jul 02, 2007 | RCA F36650 36" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Samsung LA22A450 22 in. LCD TV Logo
Henry  Thomas
Henry Thomas
