Question about Kodak EasyShare DX4900 Zoom Digital Camera
Kodak DX4900 My camera switches on it lets me format the card or look at photos ,but when i go to switch the camera to shoot mode the lens come out and then goes back in again and switches off. The batteries are the correct one and i have tried new batteries in in as well as i thought at firtst it was dead batteries. ANY SUGGESTIONS?? as usual the camera is out of warranty Thanks
  • 1 more comment
  • kodakdx4900 Aug 27, 2007
    hiya Thanks for your post.
    Tried that but memory card fine in my PC reader. Reformatted card just in case. I took the bottom of it just to have a wee look inside and it appears to have an internel battery. Do you think this is the problem ?
  • hillzy May 30, 2008
    I have the kodak easy share 4.0 . I had the same problem where the lens would come out , then retract and shut down . I disassembled the camera and but it back together and it worked fine for about a year. Lately the lens just goes in and out several hundred times then shuts down. I think it is possessed and needs a priest or a rabi or something
  • Anonymous Jun 05, 2008
    camera won't turn on at all now
    Champion:
  • 217 Answers
Try to remove the memory card first and turn it on without memory card, it has a built in memory by the way. if it works, throw away the memory card, If the problem is still there, try to shake it side by side. If it still dont works, it needs to be opened, something is stucked inside.
Posted on Aug 27, 2007
  • teofilo navarro
    teofilo navarro Sep 03, 2007
    even they are compatible, there are memory cards that works on computers and card readers but not in digital cameras! Internal battery is only for the clock and does not affect the unit operation. I also advice to format cards in your camera not in computers.
  • teofilo navarro
    teofilo navarro Sep 04, 2007
    Defective mechanism,stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
SOURCE:
Nikon d3100 will not take photos when in manual mode
Im not sure what lens you are using but the SD card holds your pictures try another card or format the same card it maybe full
test the lens by useing the old lens and shoot good luck
Mar 21, 2013 | Nikon D3100 Digital Camera
My kodak easy share camera is not allowing me to format a memory card when i insert it and therefore doeas not allow me to take photos. how can i format a memory card
This sounds like the write protection lock is on. Take the card out of the camera and look on the left hand side for a small switch. slide the switch up and pop it back in the camera and see if it will let you format it.
If the write protect lock is off then the card maybe faulty.
Good luck.
Dec 24, 2010 | Kodak EasyShare DX7440 Digital Camera
I had deleted the photos then charged the battery. when i turned on the camera to take photos it wouldn't let me shoot and the screen say's Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jul 30, 2010 | Canon PowerShot SD870 IS Digital Camera
My cam doesnt switch on
i there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 13, 2010 | Kodak EASYSHARE M763 Digital Camera
My kodak DX4900 just completely locked up and wen i turn it on the top screen says e 13
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 06, 2009 | Kodak EasyShare DX4900 Zoom Digital Camera
Formatting required after taking photos on card and dont want to lose photos already on card
Did you use the camera to format the card before you shot any pictures. If not, the camera can't use the card and used its own memory to store the photos. Use the camera to format the card, then the camera can continue to shoot more photos and store them on the card. When you download them to the computer, remember to get the one from the camera too.
May 11, 2009 | Lexar Professional High-Speed 2GB Secure...
Kodak EasyShare DX4900 E13 error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Apr 05, 2009 | Kodak EasyShare DX4900 Zoom Digital Camera
Sanyo VPC-E7 digital camera
Your Probleum is Sometimes occer when camera is put in pocket and press som keys then first on camera they shoot photo.you put to little pushing with the help of hands and then turn up and down you see your camera would worked again.
Nov 09, 2008 | Sanyo VPC-E7 Digital Camera
Kodak EasyShare DX4900 Zoom Digital Camera Logo
87 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
