Question about Refrigerators
Manual for aim refridgerator ss720 - Refrigerators
Water pouring out of the bottom
Oh you don't want that.
Jun 18, 2017 | Refrigerators
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
I cannot program the "Off" time on my GE smart digital timer model 15071
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
GE 15071/ manufactured Tork SS720
Reset timer, and try again.
Push and hold reset button with paper clip or toothpick for 3-5 seconds.
Buy new timer at Home Depot and return defect with new receipt.
Otherwise instruction manual is straightforward, and would not accept ON time unless wired correctly.
Mar 19, 2013 | Hardware & Accessories
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
How do you aim or adjust 200l legacy headlights
Hello Terry.
HEADLIGHT AIMING
CAUTION: Turn off the light before adjusting headlight aiming. If the light is necessary to check aiming, do not turn on for more than two minutes .
NOTE:
Before checking the headlight aiming, be sure of the following:
  • The area around the headlight has not sustained any accident, damage or other type of deformation.
  • Vehicle is parked on level ground.
  • The inflation pressure of tires is correct.
  • Vehicle's gas tank is fully charged.
  • Bounce the vehicle several times to normalize the suspension.
  • Make certain that someone is seated in the driver's seat.
  1. Place a cloth over the headlight that does not require aiming adjustment.
  2. Turn the headlights on. Perform the aiming adjustment for the other headlight as follows:
CAUTION: Do not perform lateral headlight aiming adjustment.There you are, the procedure from Subaru manual.
Hope this helps you.
Thank you for using FixYa.
KL
Dec 04, 2010 | 2001 Subaru Legacy
Refridgerator side is freezing while set to the lowest setting
usually the most times a thermostat will go will be upon moving ref to different location or unpluging it and repluging back in later would go with replacing thermo. hope this helps
May 21, 2009 | Amana ASD2628HE Side by Side Refrigerator
High Refridgerant Pressure
I was able to find the manual online which had the solution in the troubleshooting guide.
Jan 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
I recently obtained a PAC S1000 split airconditioner. I is an older model, perhaps 2005/2006 I have no operating manual for this unit. However having looked at this model on the Internet, it looks slightly...
They will have to be cut and brazed.
Regular solder will not hold.
High temp brazing is required.
Also, it is illegal to cut into a refridgerant system without first recovering the refridgerant. It is also illegal to tap into refridgerant systems without having an EPA certification. It can result in very hefty fines.
I know thats probably not the answer you were hoping for. Howver, I would be neglecting my duties to not inform you of it.
Again, to directly answer your question.
If there are no disconnects on the refridgerant lines, they would have to be cut, and rebrazed.
This requires recoveery of refridgerant, vacume of the system, and an EPA certification.
Jan 10, 2009 | Heating & Cooling
Aims Inverter PWRINV5000W Installation Manual I just went to install it and no manual in the box
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
e-mail:
sales@aimscorp.net
techsupport@aimscorp.net
customerservice@aimscorp.net
Jan 10, 2009 | Inverter Aims Pure Sine Wave Power...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
