Question about Juniper Networks IDP Upgrade Kit for ISG 2000 system, including IDP Lic Key, additional memory, and 5-device NSM (NS-ISG-2000-IKT) Firewall
Error codesError Text: Exception caught during Update Device: Device has returned an Error. The file might be invalid one. Return value: -106
While i wanna updating ISG, this error appear
I got code 108 eror
How to solve 108.xx, 108.08 error on Lexmark printers ~ Fix ...
fix-your-printer.blogspot.com/.../how-to-solve-108xx-10808-error-on.ht...
How to solve 108.xx, 108.08 error on Lexmark printers. A 106.xx, 107.xx, 108.xx, or 109.xx error indicates a problem with one of the ... Libell?s : Error code ...
IBM OPOS, Common Error/Return Codes - United States
www.ibm.com/support/docview.wss?uid=pos1R1000395
IBMMar 30, 2006 - I'm new to OPOS and get error return codes or result codes. What do ...108, OPOS_E_OFFLINE, The physical device is not connected or not ...
why am i getting error code 108 - QuickBooks Learn & Support
Dec 26, 2015 | Office Equipment & Supplies
Nero burn error
This is a corrupt install, Please follow the directions below, also, before you install nero 8 again, Please Turn Off any Antivirus Software, it may stop certian Drivers from Fullly installing.
Please use the Nero Clean Tools, Remove all of Nero 8, and also nero 7, if installed and any Roxio burning applications.
Install the Newest Nero 8 Update, and Put in your serial Number in the DEMO box, it will convert it to the full version.
You have a conflict, also ,
Update your Video Drivers and Direct X Drivers, They are needed to use Nero 8, You will get errors if the are not the current version's, and Nero will Run much smoother.
Let me know if you need any further help
good luck
May 06, 2008 | Computers & Internet
Trying to import csv file.
Try opening the csv file in a text editor like Notepad++ and see if there are any special characters present in the file that might normally be invisible. There is a setting to see special characters (View > Show Symbol > Show all characters).
It looks like you might have additional carriage return or linefeed characters. You could try exporting your records again and see if the csv's match.
Apr 28, 2012 | Dmitri Karshakevich E-Z Contact Book
Is showing fatal error 05 if i conact it with the tv and the pc is not showing my iomega? what to do ?
The main reason are :-
  • Access to an illegal instruction has been encountered
  • Invalid data or code has been accessed
  • The privilege level of an operation is invalid
When any of these cases occurs, the processor returns an exception to the operating system, which in turn is handled as a fatal exception error. In many cases the exception is non-recoverable and the system must either be restarted or shut down, depending upon the severity of the error.
Jul 22, 2011 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Error code 106, how to correct?
have you try to reinstall the software ??
You do it in this way, uninstall the software, reboot the computer and then reinstall the software.
If it still not work then return here :O)
have a nice day
please rate my answer
Oct 24, 2009 | Adobe Photoshop 6.0 for PC
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Excel formula
The IF() is the wrong one to use. Use "Iif()", as in:
=IiF(A3='Audit Exception Register'!B:B, COUNTIF('Audit Exception Register'!P:P,Y), 0)
See:
http://pubs.logicalexpressions.com/Pub0009/LPMArticle.asp?ID=799
Caveat about using Iif(), one that doesn't probably apply in this case, but keep it in mind: Don't use Iif when trying to return the values of "real" objects. Examples of "non-real" objects in the VB/A world are:
String
Integer, Double, etc... all the numeric "objects"
Boolean
These are fine to use in IIf() statements. If however you will be returning some value that is part of an object, as in:
Iif(x=2, myObject.getSomeVal(), 0)
You run the very real risk that is myObject is null, your program will simply stop running. Iif() will NOT return a null error/exception; it will in fact just stop. This is a bug in the VB interpreter and/or in the Iif() function itself.
I am referring here to classic VBA (ie, pre-VB dot-Net). How .NET handles such cases, I don't know.
Mar 07, 2008 | Computers & Internet
Juniper Networks IDP Upgrade Kit for ISG 2000 system, including IDP Lic Key, additional memory, and 5-device NSM (NS-ISG-2000-IKT) Firewall Logo
117 people viewed this question
Top Juniper Networks Computers & Internet Experts
David Payne
David Payne
Are you a Juniper Networks Computer and Internet Expert? Answer questions, earn points and help others
