Question about Vehicle Parts & Accessories
91 TOYOTA MR2
The car will start up fine and runs smoothly for about 5-10min. It wont start again unless I wait about a few hours. The fuel pump isnt making a sounds when the ignition is turn on, so Im not sure if it could be a relay or the pump its self, the fuel line leaked gas when I removed the tank.
  • 53 Answers
It sounds like a bad fuel pump that is getting hot and not pumping fuel.
Posted on Jul 10, 2013
  • 12 Answers
SOURCE: x5 wont start turns over but wont start replaced
you have what is called a module in the distributer if that is starting to go out your vehicle may do that but completly out you have no power at all.if your fuel pump was out and it may have not.the way you test fuel pump find your fuel line disconnect the fuel line have someone try to bumb start the vehicle no fuel coming out of line then its your fuel pump did you do that first? check all fuses check all sensors that has to do with the starting or electric part of your vehicle not to be confuse with the emission control system that has nothing to do with starting of vehicle.check your distributer and your electrical coil witch is located next to distributer in order to save you money i allways do this go to service and parts the service person can look up faster and you can a print out to know what to check or a key that goes to your computer that is located under the dash board read your codes on your dash auto parts stores use to carry these and shows what codes in order to find out what the cause is.
Posted on Jan 29, 2011
  • 36 Answers
SOURCE: I have a 2007 Volvo
It did happen to me too.Is true that i had another mark but anyway , you can look on it. Gas hose can be throttled and cannot let the fuel to accelerate the engine how it should.Good luck.
Posted on Jun 12, 2011
  • 6 Answers
SOURCE: fuel pump assembly repair6 month old delco pump,the nipple on the pump where the line going to motor is split down the side can i replace just the top of pump asembly this pice is made of plastic and
you will probably have to replace the whole thing as these are one piece units
Posted on Jul 05, 2012
sxygaman
  • 95 Answers
SOURCE: 2001 tj jeep no fuel pressure at tank
leaking fuel tank or bad vent tube creating air pocket
Posted on Aug 12, 2012
spiderman699
  • 4 Answers
SOURCE: Does my Toyota camry 93 need the fuel pump fuse or relay to run?
unless some one has riged it so that it will or they are pouring gas down the intake ..yes.
Posted on Mar 03, 2013
My 2008 dodge avenger wont start
many possibilities but start with fuel pump. intermittent issue.
Aug 23, 2015 | 2008 Dodge Avenger
Will start , runs good, but will not start again when shut off, sits a few hours, will start again, is it the fuel pump?wont shut off or stall while it's running
No its not your fuel pump if it was it would not start at all or make the motor run i would suggest you renew your coil
Apr 12, 2014 | 1996 Toyota Camry
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
Cant fine were the fuel pump relay is on my 91 mr2 2.2 non turbo
LOOK FOR FUEL PUMP FUSE LEFT SIDE KICK PANEL ON DRIVER SIDE.
Jan 19, 2011 | 1992 Toyota MR2
91 acclaim v6. starts and runs good, but once its been running for awhile (hour or so), and i turn it off, it doesnt want to start back up, or does and dies. wait 2 hours and it starts right up. recently...
Sounds like either you have a clogged fuel line and or clogged fuel filter or the fuel pump is failing. What happens when the vehicle runs the fuel pump heats up, as it heats up it produces less and less fuel for your car. Eventually ti stops working until its cool again on faulty pumps. Given the age of your vehicle I would say you need to replace both pump and filter.
Sep 19, 2010 | 1991 Plymouth Acclaim
97 lumina, 3.1. Starts runs smooth, drive for 30
I just recently have been fighting the same problem with the same make/model/year vehicle. For myself, I would drive off and on through the day and it would run fine. Then suddenly after a start it would run rough and die. I would have to wait 20 to 60 mins before it would start again. I had it checked and fuel pump was only putting out around 19 psi. It should be around 41 psi. Had fuel pump replaced and no more problems. Furthermore, now it runs so much better. It's funny how over time I didn't notice how the performance was slowly degrading. Unfortunaley fuel pumps for this car run around $300.
May 25, 2010 | 1997 Chevrolet Lumina
89 mr2
Are you sure its no spark? It could also be a bad fuel pump... have you done a check for spark? If you pull one of the plugs out and lay it on the engine block and turn the car over a few times you don't see spark, or it just doesn't fire when it cranks?
I suggest you perform this test. If you see spark I can almost guarnatee that its a fuel pump issue.
Try this test if the one above passes. Pull off the intake hose (big thick hose attached to the throttle body) and spray in some starting fluid. If it cranks and tries to run but then dies, that suggests that there is no fuel getting to the motor which is usually a bad fuel pump as relays and fuses usually don't burn out on their own. These two tests should narrow it down pretty significantly. Hope this helps! Good Luck!
Aug 17, 2008 | 1989 Toyota MR2
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
