I have a hp g71 449wm laptop i made repair disk but when i turn my laptop on it goes to black screen how do i run the repair disk when it does this? Please help
    Top Expert:
  • 12,223 Answers
Restart the computer HOLD THE KEYS CTRL+f11 or f12 depend of your model, mark and restore the factory default and fix it.
God bless you
Posted on Jul 10, 2013
SOURCE: gateway laptop
It would amaze you just how cheep a motherboard is and how easy they are to replace. You can get one for this laptop for under $100.00 off fleabay and it is worth it. Its worth it to me anyway...LOL
Posted on Jun 02, 2008
SOURCE: hp laptop wont restart
google translate sucks so so so so bad
Posted on Aug 24, 2008
Ray-Tosh
  • 124 Answers
SOURCE: Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Posted on Sep 28, 2008
  • 17 Answers
SOURCE: hp pavilion dv9000 screen and factory settings
*Actually*, with regards to the screen issue, software CANNOT cause a failure when the display assembly is physically moved....The two possibilities are the LCD harness (video cable) part# 432962-001 OR the actual LCD itself (part# LP171WP4 (TL)(03) for most models). My money's on the cable, not a stupid driver...
Posted on Jun 10, 2009
LaptopExpert
  • 458 Answers
SOURCE: upon boot up, screen remains black,disk power up briefly
HOW TO FIX YOUR DV6000/DV9000/DV2000/tx1000/tx2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 04, 2009
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
My lenovo s10-3 has turned a black screen after i go to system restore
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 25, 2012 | Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
May 21, 2012 | Toshiba Computers & Internet
My hp computer stop working
Blue Screen of Death (BSOD). Try running the check disk utility.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk does not solve it you might have to reinstall windows.
May 01, 2012 | HP Computers & Internet
I have a nx6100 hp laptop, when i turn it on the screen just goes black with an hp logo in the middle of the screen and an f10=ROM based setup at the bottom and it stays like that,, how can i fix...
i think it is a hard disk problem. on screw and set well your hard disk. start the PC. it may be run. if not format and install operating system again.
Aug 27, 2011 | Computers & Internet
My hp w1707 is not working...when i turned my computer on the screen lights up with windows then it goes to black with a dash flashing in the upper left hand corner and stays there
you need to get a disk of your version of windows and run a repair. the vista/7 disks have a start-up repair option, and xp disks have a "recovery console". if you are doing xp, try running "fixboot" and "fixmbr" commands at the recovery console command prompt.
Mar 12, 2011 | Computers & Internet
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Screen goes blank after windows loads
Hi there
If you tried in safe mode and still no joy you will have to perform a system recovery with the recovery disk you got with the laptop or the recovery partition, Please be aware that you will loose data.
Good luck
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
HP Pavilion DV6000 with Vista
These are well known for VRAM failure and HP extended the warrany for an extra year regarding this model. If they refuse to repair free contact us back..
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
