Pioneer RT-909 ff and rewind but play
Pioneer reel to reel tape deck, will fast forward and rewind but will not play
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Posted on Jun 20, 2008
  • 4234 Answers
SOURCE: RX-303 NAKANICHI & TEAC-2000X REEL TO REEL
These decks need a complete overhaul. There are belts and "idlers" inside that are made from rubber that have dried out and slip. The Rx-303 needs a tire replacement. This tire only comes into play when in play mode. The FF and REW functions are powered only by a belt. Changing hte idler tire is a bit tricky in these units if you have not replaced one before. Given the value of these units, I'd recommend that you have a servicer in your area overhaul these. The parts expense should not exceed $15 for either deck. Check in the area for the labor costs. Both units are definately worth the repair cost.
Dan
Posted on Aug 08, 2008
  • 11 Answers
SOURCE: ''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Posted on Apr 13, 2009
SOURCE: Sony TC 330 reel to
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Posted on Apr 17, 2011
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Pioneer rt707 ...ff & rewind buttons work...play
I have not seen a RT707 but in the RT909 there are reel settings for the reel motors as far as torque goes. A copy of the service manual will tell you how to set these tensions. I suspect that you have a setting that favors one direction.
Feb 01, 2013 | Audio Players & Recorders
I have a pioneer RT-909 reel to reel unit
This is a matter of the safety switch microswitches and the tension arm rollers and lubrication needed. I have replaced these 30 year old microswitches in the past and had to deal with the shut off issue as well. To get to the parts you need to take the machine apart somewhat- front panels off and so on. I have had 9 of those here in the last year.
If you want my help in the Chicago area- skywavebe @sbcglobal.net
Aug 14, 2012 | Pioneer Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
Oct 15, 2010 | Sony Audio Players & Recorders
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Apr 08, 2009 | Audio Players & Recorders
Tape adjustment
Jazzie: Your pinch rollers are worn. Put in a new set and probably a drive belt while you're at it and you'll be back in business. When the rollers are worn and tapered, the tape just rolls right off. Be sure to get the Pioneer replacements! Part---- RXB-325
Oct 29, 2008 | Audio Players & Recorders
29 people viewed this question
 Grubhead
Grubhead
