Question about Intermec Computers & Internet
Scanner problem Hello everybody, I am having problems with my Intermec CS40 terminal. The scanner is working,but when I want to scan a barcode it sounds very strange and the barcode is not displayed on the screen.The green LED that is on when you make a good scan is turned on but the sound is not an regular sound for a good scan. I tried different barcodes but the result is the same. Please help me with this issue . Thanks
  • 58 Answers
SOURCE: Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Posted on Dec 07, 2007
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
geras2000gas
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
First:
a) Do you have the scanner connected to an Y cable ?
If yes, you need to connect to the PS/2 port on the computer and you have to connect another 101 keys keyboard
/ PS/2 computer port
scanner ----
\ 101 keys keyboard.
restart the computer and will work.
the system will include the driver in the keyboards.
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
b) if you do not have the Y cable:
just install the driver : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Good Luck
Posted on Dec 04, 2008
My mc9500 handheld device scanner is not working. when i try using the demo application in the device and also other application to scan, it gives a message "scanner is busy, try closing the applicati
Hello David!! In order to better assist you to isolate the problem and trying to resolve it. You can visit Our Motorola Website that specialize in mc9500:
MC9500 Premium Industrial Class Rugged Mobile Computer
Best Regards.
Karen
Customer Support
Aug 15, 2014 | Motorola MC9500K Handheld Mobile Computer ...
Scanner setting
Got to the following:-
Start >> Settings >> System >> Intermec Settings
You are then presented with all the settings you can change within teh device. From here got to:-
Data Collection >> Internal Scanner >> Symbology Options >> Postable
You are then presented with an input field. Enter your (13) here and hit [OK] to save and exit.
Use notepad on the device to check that the 13 is placed at the end of the {Barcode Date}
I confirmed this on a terminal we have here and it worked 500011972829613
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 03, 2012 | Intermec CN70 Handheld Mobile Computer...
Scanner reads some barcodes (black and white, larger barcodes), but not smaller barcodes that are black w/gold background.
Acutually, some kind of conbinations of bar color and background color will prevent barcode readers from accurate scanning. So I think you should check whether your color combination is feasible first.
I want to attach an image, but it is too big to upload.
Feb 08, 2011 | Intermec CK31 Barcode Scanner
REQUIRED DRIVER FOR INTERMEC PF8t BARCODE PRINTER
http://www.intermec.com/support/downloads/index.aspx
here is the download site we use for intermec downloads its safe fast and free good luck
please remember to rank this advice
sonic boom electronics
Dec 28, 2010 | Intermec Cable (USB Adapter) for Keyboard...
Menu is Blocked error
Look for, and scan, the "Enable Override" barcode in the Intermec Trakker Antares 2400 Family System Manual, available in the manuals section of intermec.com.
Apr 17, 2009 | Intermec (T2480B3B45061) Network Terminal
Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Feb 11, 2009 | Intermec Computers & Internet
1551B Cables
Yes
you can configure the scanner to match your laptop as long as the cable connects properly
you should be able to print out barcodes to scan to configure
go to intermec.com
or scansource.com technical support
or cal scansource tec support and they can tell you over the phone
best of luck if youhave any questions just respond
Jan 06, 2009 | Intermec 1551B (1551b0700) Handheld
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
Computers & Internet Logo
51 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
