Question about Garden
Mower will not start
It will not start gas will get to the carburetor but no starting I can put gas in the carburetor sometime it will start.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Sounds like you need to check compression has to be above 90 lbs to start try squirting some starting fluid to start it and keep squirting it keeping it running you could have drop a valve doing this will reseat it but if thats case get new motor
Posted on Jun 07, 2014
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Poulan pro lamn tractor will not start
Carb is most likely clogged from when the gas you had in it before gummed up. Take some carb cleaner and clean the heck out of the carb and everything will work just fine after that. I also recommend letting the carb cleaner sit for about 30 minutes before trying to start the machine
Posted on Jun 03, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
  • 691 Answers
SOURCE: Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Posted on Sep 01, 2009
Testimonial: "This guy really knows what he is talking about. I would highly recommend him."
SOURCE: Snapper riding lawn mower will not start
If you have good spark and the carb is clean what kind of shape is the fuel in your mower?
You might want to empty the fuel system out completely and let it dry out to remove any water that may have accumulated in the tank.
Have you tried putting a splash of fuel into the carb and trying to start it?
If it starts on a splash of fuel you still might have a blocked main jet or stuck fuel float.
Posted on Jul 29, 2010
Troy-bilt mower will not start. If I put gas directly in carburetor it will start but appears to not be getting fuel.
Darlene, if it will start with gas poured in the carburetor. it is fuel relater. take the carburetor off clean it real good and it should run as good as new.
Jun 03, 2016 | Garden
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
The riding mower has been used in June. Now when I try to start it I cant. I have checked the battery, gas, etc. before trying to start it. What can I do now?Thanks
put gas right into the carburetor and see what happens. if it doesn't do anything then you have a spark issue, if it runs until the gas you just put in runs out then it is a carb issue. sometimes just priming the carb with gas will get it to run again too
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
Smokes a lot on starting runs for 2 min. then stalls
check oil level. See if it's high. sometimes when carburetors start to go bad, they let gas flow into the carburetor throat that ends up in the cylinder and down into the crankcase. does the oil smell like gas?
Aug 26, 2013 | Yard Machines 155 Torque Briggs Stratton...
My Craftsman Lawn Tractor 18.5, 42"Mower with Electric Start and Automatic Transmission won't start. (model# 917.275760) won't start. I have put new air filter, fuel filter, battery and spark plug...
Try looking at the screw that holds the bowl in place, sometimes they have a little orifice on them that gets clogged and hinder fuel from reaching carb. Use a small pin or small gauge wire to clean. Good Luck...
Apr 21, 2011 | Garden
Ran out of gas, put gas back in. will not start again. will run on starter fluid but dies when it runs out. sat for a day, started and ran 2 min. and quit. there is bolts under the carburetor -- is...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 15, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Mower does not start.it appears that when priming to start that it is not getting gas.how do i fix the problem
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Aug 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a troy push lawn mower with a Honda engine. I have had it for 4 years now. The problem Im having and been going on for a couple of months, It wont start. Sometimes it will but i need to use carb...
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 30, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you get to the carburetor in a Yard Man
Take off the air cleaner an pour in a tablespoon of gas, if it runs for a couple seconds, then you have a carburetor problem. If not, maybe spark plug problem.
Apr 05, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
