Question about Refrigerators
There is supposed to be a foot that holds it in place but installers muat not have locked it. fridge slides back iand iist slide back put every few dat to keep useable
  • Refrigerators Master
  • 17,328 Answers
Not a foot but there are level adjustments that can be set and some of these are pegs that touch the floor. Look under and see if you see them. Some models have screws that adjust the roller height too.
Posted on Jul 10, 2013
fridgetech
  • 473 Answers
SOURCE: slide lever for temp control
I will need to know the model # that is on the sticker inside the refrigerator to help. Don't use the # off of the manual.
Posted on Oct 10, 2007
  • 20 Answers
SOURCE: fridge freezing everything
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
Posted on Feb 02, 2009
  • 78 Answers
SOURCE: I have Frgidaire Gallery Model FRS26ZGGD..I rec'd
call sears
Posted on Dec 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: freezer and fridge doesn't get cold enough, I keep
Is there a lot of frost accumulation on the back wall of the freezer section. If there is your auto defrost has a proble. All inexpensive repairs. Is the evap fan running in the freezer. You should be able to hear this when you open the freezer door. If you do not hear the fan you need a new evap fan. This is what circultes the air for proper cooling.
Posted on Feb 02, 2010
woodchuck789
  • 4070 Answers
SOURCE: gi5fsaxvy french door fridge ice maker has frozen
This diagram shows two screws on the top and there is one on the bottom. Loosen the screws and ice maker should lift off. You may just want to use a hairdryer to melt it and your water inlet valve on the back where the water supply is connected may be leaking letting the water drip into the ice maker and freezing when it gets there. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW1010173-00005.png
Posted on Nov 17, 2010
Testimonial: "Thanks for the tip! If there's a screw back there against the wall then there's an ice dam blocking it, so time for hairdryer until it all melts :)"
How to put chain back on when it falls off
Almost every saw has a cover where the bar locks onto the saw, you take off the cover just as you do if you needed to remove the bar.
Just loosen the two or one bolts that hold the bar and slide the bar back, put on the chain and slide the bar back out.
Now there is suppose to be some play, the chain is not suppose to be very tight.
Here is what it suppose to be like.
Read this link that I post, it's easier to read this then me trying to explain it.
http://www.instructables.com/id/How-To-Tighten-a-Chainsaw-Chain/
Apr 14, 2013 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
    Good day ,
    The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
    if so put a little lock tight on the pin and push it back in it should hold again
    good luck
    Gordy
    Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How to change front discs on vw polo
    click on this link directlyhttp://www.aepdirect.com/?option=shop&&page=shop.product_details&category_id=5371&product_id=4051
    Caliper With Guide Pins Disconnect the negative battery cable from the battery. Remove the wheel. Using an open wrench hold the lower guide pin. Remove the bolt that secures the caliper.
    Pivot the caliper up and then suspend it from the frame using mechanic's wire. To remove the pads, slide the pads straight out.
    Clean the old bolt and apply thread locking compound. If the old bolt can not be used install a new bolt. Hold the guide pin using a back-up wrench when tightening the bolt. Using a torque wrench torque the bolt to 26-ft. lbs. Install the wheels. Add oil to the master cylinder reservoir. Reconnect the negative battery cable to the battery.
    Caliper With Sleeves and Bushings Disconnect the negative battery cable from the battery. Remove the wheel. Remove the bolt that secures the caliper to the carrier.
    Push the caliper up and pivot the caliper bottom out of the carrier. Remove the pads and the anti-rattle springs.
    Install the new pads by putting the anti-squeal pads onto the caliper and then sliding the new pads onto the carrier. Put the caliper top back into place. Remove the mechanics wire and push the caliper up so that it pivots back into place and the bottom.
    Clean the caliper mounting bolts. Install the caliper mounting bolts and using a torque wrench, torque the bolts to 18 foot/pounds. Install the wheel. Add oil to the master cylinder reservoir. Reconnect the negative battery cable to the battery.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Feb 28, 2010 | Volkswagen GT Cars & Trucks
    Not sure how to use the buttonhole foot J that came with my 712T machine. I guess I don't understand the sliding part. Are you suppose to guess at the buttonhole size or do you use the button somehow to...
    The buttonhole foot slides open so that you may insert the button which you are making a button hole for so that it may be sized correctly.
    Slide open the foot, place the buttin on the spot and slide it closed.
    Turn the pattern selector off and back on to the buttonhole pattern to reset. (Do this each time you make a buttonhole to reset)
    Pull down the buttonhole lever located up and to the left of the needle bar. Pull it ALL THE WAY DOWN so that it will be tripped by the buttonhole foot as it moves.
    Set the stitch width to about 4 or 4.5.
    Set the stitch length to a very tight stitch (but usually slightly higher than the recommended marking)
    Set the upper tension on 3.
    Use an appropriate stabilizer. This is the key to a good buttonhole.
    Lower the foot on the fabric, ensuring that the foot goes down without springing forward or back.
    Make a few practice buttonholes, adjusting the width and length untill you get what you are looking for.
    Jan 16, 2010 | Janome MyExcel 3123
    My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
    How to install sentry safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Aug 26, 2009 | Sentry Fireproof Safe
    How to replace the front brake pads
      Calipers With Guide Pins
    1. Step 1 Disconnect the negative battery cable from the battery. Remove the wheel. Using an open wrench hold the lower guide pin. Remove the bolt that secures the caliper.
    2. Step 2 Pivot the caliper up and then suspend it from the frame using mechanic's wire. To remove the pads, slide the pads straight out.
    3. Step 3 Using a C-clamp, compress the caliper piston into the bore. Insert the new pads by removing the mechanics wire and pivoting the caliper back into it's place.
    4. Step 4 Clean the old bolt and apply thread locking compound. If the old bolt can not be used install a new bolt. Hold the guide pin using a back-up wrench when tightening the bolt. Using a torque wrench, torque the bolt to 26 foot/pounds. Install the wheels. Add oil to the master cylinder reservoir. Reconnect the negative battery cable to the battery.
      Calipers With Sleeves and Bushings
    5. Step 1 Disconnect the negative battery cable from the battery. Remove the wheel. Remove the bolt that secures the caliper to the carrier.
    6. Step 2 Push the caliper up and pivot the caliper bottom out of the carrier. Remove the pads and the anti-rattle springs.
    7. Step 3 Install the new pads by putting the anti-squeal pads onto the caliper and then sliding the new pads onto the carrier. Put the caliper top back into place. Remove the mechanics wire and push the caliper up so that it pivots back into place and the bottom.
    8. Step 4 Clean the caliper mounting bolts. Install the caliper mounting bolts and using a torque wrench, torque the bolts to 18 foot/pounds. Install the wheel. Add oil to the master cylinder reservoir. Reconnect the negative battery cable to the battery.
    Jul 09, 2009 | 2006 Volkswagen Jetta
    Refrigerators Logo
    44 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
