Question about Lux TX500E Smart Temp Digital Programmable Thermostat
How to reset - Lux TX500E Smart Temp Digital Programmable Thermostat
Where can I find reset button and is there only one reset button
http://www.marathonheaters.com/useandcareguide.pdf Upper thermostat has only reset button.
Jul 31, 2014 | Marathon Lower Thermostat - Standard -...
Where is the reset button on reliance gas water heater
No reset button.
The gas control valve is the thermostat
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Intellivent gas control can be reset, and Honeywell can be reset under some circumstances.
Otherwise, bad thermostat means replace gas control valve
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 28, 2014 | Reliance & 50gal Electric Water Heater
How to reset filter indicator on luxpro psp511lca
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Jul 17, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Oct 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have an AO Smith Model EES 52 917 hot water heater. This morning my hot water suddenly disappeared. I have tried resetting the breaker with no luck.. I am not sure what else to try.
You have electric water heater.
Inside the upper panel on water heater is a thermostat with red reset button.
1) Click the reset.
2) Put insulation back over thermostat so it is not exposed to cooler air, so it reads correct temperature.
After resetting thermostat, you will have hot water.
The reset automatically clicks off when thermostat detects temperatures in excess of 150 degrees.
The re-set is a safety device, and it keeps everything safe.
If reset will not 're-set' with cold water in the tank, then thermostat is bad, replace thermostat.
You can repair electric water heater yourself following steps on links below
If the reset clicks off again, just reset it
This is not a dangerous situation
Reset thermostat as many times as necessary until you can fix the problem
If you have trouble fixing the problem, add a comment at bottom of this page and it sends me an e-mail and I will help further
Thermostats with ECO red reset
Oct 26, 2010 | Water Heaters
New water heater installed in Jan.2010, first no hot water at all, replaced top element have hot water now but reset button trips and have to reset it when all hot water is used. Any ideas what is wrong?
The reset switch works like a thermostatic breaker and although unusual, it is possible the reset switch is bad or weak. You can replace the reset but some are hard to find. It may be easier to replace the upper thermostat with reset. I would also suggest that you check with the vender you purchased it from, and relay your story to them as they may be willing to help you with the parts. I hope this helps.
May 22, 2010 | RELIANCE ELECTRIC WATER HEATER
The Thermostat does not reset!!!
Hi jamaica,the reset pops on tank/water tempature. The unit is overheating or the reset/saftey has become defective.Recommend replace thermo.
Mar 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Lux TX500E Smart Temp Digital Programmable Thermostat Logo
32 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
