Question about Kitchen Ranges
Front right burner on ge jgs968 slide-in gas range wont light
Gas range. I turn burner on and hear clicking sound but burner never lights
  • 1 more comment
  • Geoff Huckleberry Aug 01, 2013
    Thanks, Brian. Gas flows, it just doesn't ignite. Is the lighting element something I can replace myself or do I need a technician to come out? I assume the retailer (sears) or manufacturer (GE) stocks the part.
    And... if I can replace, do you know how?
    New Friend:
First you need to find out if you have actual gas reaching the element. Can you light is with a match. If you can't light it you have a clogged gas line and will need to find out if it is the tip or the line. If it does light with a match, then you will need a new lighting element.
Posted on Jul 15, 2013
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
bestdarngood
  • 3037 Answers
SOURCE: Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Posted on Apr 27, 2009
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
My jgs968 oven won't light. It stays at 100. The burners and broiler work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
m,b,m
Jun 24, 2010 | GE Profile JGS968 Gas Kitchen Range
Two of the burners on the left side doesn't light.
If you small gas, then there should be gas to burners, If you are hearing a clicking, but doesn't light, then your igniter may be corroded or faulty all to gether. You can get parts and manual at repairclinic.com
Oct 22, 2009 | GE JGBP28 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Burner won't light
Take the pot support and the burner cover off and clean all the slots out with a toothpick. Carbon builds up over time and the gas doesn't flow over the spark. Do not light until fully reassembled.
Feb 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Ge spectra gas stove top not lighting
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
