Minolta diALTA DI550 error code C0990
PROCEDURE TO FIX THIS PR4OBLEM
Soulvisitor
  • 1113 Answers
SOURCE: Getting a error code C0F37 on a Minolta Dialta CF1501
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Posted on Nov 18, 2007
sir fixalot
  • 146 Answers
SOURCE: minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Posted on Nov 11, 2008
  • 990 Answers
SOURCE: Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 87 Answers
SOURCE: minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Posted on Dec 18, 2008
  • 1602 Answers
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
Posted on Feb 13, 2009
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
How can i fix the error code C0990 on minolta di550
Main Tray lifting motor Your large capacity draw. Require knowledge of the draw lift system recommend. have a tech look at it
Jul 10, 2013 | Minolta Di3010 Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
Minolta Dialta DI-550 hard drive
Rear of the machine left side mite be covered bye one board
Feb 27, 2012 | Minolta Di550 B&W Laser Printer
Error c0990
large capacity draw fault, broken gear in the front of the draw mite got rounded out originally gears is a half moon inner circle.
Nov 11, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Jan 08, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error c12co in minolta di550
C12CX (X is any value)
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
MINOLTA DI350 code C0990
Open the bottom drawer and check for any jammed paper or add more paper. :)
Sep 25, 2007 | Office Equipment & Supplies
jasbo
jasbo
