Question about Electrical Supplies
I have a powermax xp3500 generator and I changed the oil and then started it up and when it running for about 20minutes it shuts off and it has leaked the oil out looks to be inbetween the motor and the generator
SOURCE: generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Posted on Sep 21, 2008
  • 11 Answers
SOURCE: Generator won't start
Some of the generator has a control or tripping device like over speed, over voltage, overload or overcurrent or other trip device, try to find & reset it.
Posted on Mar 21, 2009
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
  • 1114 Answers
SOURCE: fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
The car starts normal, then shuts off after 20minutes. then it doesnt generate spark on spark plugs. and repeats (starts whenever it wants) would it be a problem with the coil?? I checked with electrician...
If your Lanos runs for a short time and no spark have been generated when these problem occurs, the problem would be in the ECU, which you have to bring that to the dealer for a thorough scanning( one of the sensors is malfunctioning ), and the other one is the ignition coil that is overheating.
Hope that helps you out!
Aug 14, 2011 | 2000 Daewoo Lanos
Just changed oil on the 4200 watt Craftsman generator, motor starts and runs 2-3 minutes then automatically shuts off for no reason. Any ideas on how I can solve this problem?
make sure you put the correct type of oil in the crankcase for this machine
if you use the wrong type of oil ,oil level sensor float wont work and causes a shut down to protect the generator engine from damage
try draining oil and refilling with 20w/50 oil
cheers pauly46
Apr 03, 2011 | Craftsman Garden
Fipped over
Aug 08, 2009 | Coleman Powermate Premium Plus 6250W...
Powermax water pump shuts off after 5 min or more
Either the coil/HEI module is bad or your on/off switch(kill switch) is bad. Check those first.
May 19, 2009 | Powermax XP650WP Portable 3' Water Pump...
Generator shutting down after 1.5 of run time
Sep 20, 2008 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
