Question about Cell Phones
My LG-LS970 Optimus shut off and it won't come back on? What do I do to fix my problem?
It keep shutting off before but this time it shut off and it's been off for like a month now? How do I fix it or reset it when it don't come back on!
SOURCE: it shut off and wont turn back on
Try pulling the battery for 15 seconds or so. It should power up.
Posted on Mar 12, 2009
SOURCE: lg dare keeps shutting off
Go into phone settings, then security after putting in your four digit code click on reset default. Your preference settings will be set to factory defaults and your user data will not be erased. DO NOT CLICK ON RESTORE PHONE! That will reset your phone and erase everything such as contacts and pictures.
Posted on Mar 25, 2009
SOURCE: lg versa shuts itself off couple of times a day
There is a shock sensor in the phone and any slight jarring will turn it off to protect the circuitry (if you drop it good)... it may be annoying but it is a decent feature.
Posted on Oct 05, 2009
Pathricko
  • 55 Answers
SOURCE: My optimus m phone shuts off and then comes back
that usually happens when the power is low, fully charge your phone or change the battery
Posted on Mar 13, 2011
SOURCE: my lg gt540 optimus won't boot up it switches
http://androidforums.com/lg-optimus-s/242079-lg-optimus-wont-respon-turn.html
Posted on Oct 02, 2011
What do I do if my phone keeps shutting off when its fully charged but when I try to take out the battery and put it back in it just starts blinking like crazy?
Your battery is dead. You can simply buy another of the same battery. Rechargable batteries do lose their charge for good after a certain amount of time.
Sep 12, 2014 | LG Optimus V 3G Prepaid Smartphone w/...
LG LS970 wont reset stuck on system screen wont show keyboard
take the battery out of it and start over..
Jan 12, 2014 | Cell Phones
I have a LG optimus select and it won't let me
Go to google play and download bs player
May 30, 2013 | Cell Phones
Keeps showing lg screen and flashing
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when:
- phone battery is allowed to die
- pull battery from phone when it is still shutting down (hard to tell when it's finish)
Dec 28, 2012 | LG Optimus Net P690 Touchscreen Android
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
How do I get the metropcs lg optimus ms690 to read the sd card?
Put card in. then shut phone of for a min. When you turn it back on the phone will search and find it,
Apr 21, 2012 | LG Cell Phones
My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Nov 16, 2011 | Computers & Internet
Stops 5-10 min into exercise; trips breaker,
Dear Sir:
Thank you by your request. I hope everything is o.k
Now I will try to help you.
You have electrical-mechanical Problem:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact us with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or
some call it a console.
Thank you in advance, sincerely. God bless you.
If you need additional Help , please contact me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Bowflex Treadclimber
I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
Dear Sir:
I hope your are very well in union with your family.
I will help you inmediatel.
Please do the following:
1)
The amount of time required to shut down will progressively get shorter.
2)
the deck for wear too. If you want to go for a cheap fix try lubricating the walking
3)
case corrosion is causing.
If you need further assistance,please contact us.
E.CUADRA
Sep 27, 2011 | Exercise & Fitness
Cell Phones Logo
326 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
