Question about Broan 41000 Series 24 in. Non-Vented Range Hood in White 412401
Id 410003 24 activation Code corldraw x6
Activation Coe
Model # RY 160LXTS sometime the broil come on by it self, causing the smoke alarm to goes off, what can I do to fix this problem, the range is 2 1/2 years old
if this is the model with the touch control buttons on front , ive seen a stove top spill that got down inside there cause some missoperation ,id start to look there for a reason , then id move on to replacing the control panel and last the logic board (its on back of front panel ) but I will say id unplug it till I resolved this problem if it turns itself on and your not home ,what could happen !!!!
Apr 09, 2016 | Whirlpool 4.5 cu. ft. Electric SlideIn...
Ernestb713@verizon.net
On the verizon.net sign-in screen, click the "Forgot User ID or Password?" link.
Nov 28, 2013 | Cooktops
We are in need of a Tech Manual for a VGRT5364G conversion from LP to Nat. Gas. Thanks
Manual exist in the location: http://www.retrevo.com/support/Viking-Range-VGRT536-4G-Ranges-manual/id/23666dj391/t/2/
It clearly mentions that:
"A certified
technician is required for any adjustments or conversions to Natural or LP gas."
So pls dont' try unless you already know (and it seems that you don't)
Safety comes 1st!
Jul 28, 2011 | Viking VGRT5364G Cooktop
My Zanussi Induction cooker model ZKT 621LX is not working? When I try to switch it on, the display for all 4 cooking zones shows L and after a few seconds, it just shuts off? What could be the problem?
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Apr 19, 2011 | Zanussi 23 in. ZKT641H Electric Cooktop
I have a Frigidare range with self cleaning oven. I can't use the oven because it keeps telling me to lock the door, which starts the self cleaning process. If I try to start the oven it tells me the door...
the door lock motor assly could be bad.during self cleaning process the motor runs and locks the door and activates a switch .the control reads the swithch.if motor does not tunrn the door is not closed and it does not activate the switch.at the maximum it could be the control itself gone bad and able to read the switch.but that is less likely.
Jul 28, 2009 | Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Apr 15, 2008 | Cooktops
Broan 41000 Series 24 in. Non-Vented Range Hood in White 412401 Logo
15 people viewed this question
Top Broan Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Broan Cooktop Expert? Answer questions, earn points and help others
