Sony Cyber-shot DSC-W100 Digital Camera
Problem for Sony Cyber-shot DSC-W100 Digital Camera
My Sony DSC-W100 says "Turn the power off and on again" but still wont take any pictures! The...
By Bekaking on Aug 26, 2007
When i turn the camera on it says "Access" and then "Turn the power off and on again".
I have turned it on and off over and over again! The lens comes in and out 3 times but i can't see what is wrong with the lens (as it looks normal!).
At first i thought the battery must have ran out so i charged the battery but i still have the same problem!
Does anyone know what is wrong with it and how i can fix it?
If i have to send it to someone to get fixed does anyone know how much it will cost, or should i just buy a new camera?
Same Problem
Nov 24, 2009
-   =( its not working for me... -   mjgeneroso
Oct 24, 2009
-   THANK YOU! THANK YOU! Although this message is coming 2 years after everyone has posted- I tried the dropping onto the carpet, but the banging thing worked for me the first time, not the dropping. -   jasmine596
May 23, 2009
-   I have exactly the same problem. I really dont want to buy another camera-   Guest
Apr 09, 2009
-   The lens protracts and retracts 2-3 times and the displays the message "turn the power off and on again". I have taken battery out replaced it, formatted card, initialized it, held shutter button down, shaken it, tapped it, bashed it and am about to smash it....
Your help would be greatly appreciated..
Thanks -   kamonardo
Feb 15, 2009
-   Same problem here. Camera will not power on and lens goes in and out 3 times before saying "turn off and on again". The times that I have gotten the camera to power on it will not focus so pictures can be taken.-   channels007
Best Solution
posted on May 26, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
wow...it is sad to say but the bangin on the camera worked for me too....that's really sad for SONY
Solution #2
posted on May 17, 2008
Very Helpful)
ndsonyuser
Rank: Apprentice
Rating: 98%, 3 votes
Had the same problems. Unbelievably the after slamming it lightly on the floor the camera now works. Now I know what works. I am a believer!!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Mar 12, 2008
Very Helpful)
Rajasubbiah
Rank: Apprentice
Rating: 86%, 8 votes
I had the same problem.The carpet solution seems to be foolish. But still i tried the same today ... Its really a Surprise ... My cam is working properly.. Its really a shame for you SONY
Was this helpful?
Yes
No
Solution #4
posted on Feb 19, 2008
Very Helpful)
bluespoon25
Rank: Apprentice
Rating: 97%, 11 votes
OMG - I had the same error, when I turned the camera on it said "Access" and then "Turn the power off and on again".
I have turned it on and off over and over again! THANKFULLY I took "Guest's" advice from September 12, 2007. After hitting it a few times on the carpet, I still received the error, BUT while the lens was retracting in and out I hit the top of the camera beside the power button with my knuckle and it WORKED!!! I can take a picture again. Thanks so much for the advice. Hope this helps others.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #5
posted on Mar 22, 2008
Very Helpful)
gapaeach
Rank: Apprentice
Rating: 95%, 2 votes
Amazed that the rapping of the camera (a little harder than with a knuckle) worked for me too!!! Good grief...
Must comment that the problems with my camera began only after having carried it in my purse (without being in a case---I know, STUPID) where I'm sure the lens would have been bumped and/or had pressure from other items in the purse putting weight on it when it inevitably ended up in the bottom of my huge purse.
Moral of the story: carry this camera in a protected case when transporting---because prior to that I never had ANY problems. Moreover, the whole thing is lens related and we all know an automatic lens is a sensitive instrument!
Thanks for a remedy born of frustration!
gapeach
Was this helpful?
Yes
No
Solution #6
posted on Sep 12, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue. Lens would move in/out say 3 times but camera did not start - Power off message. Suspected jammed gears - So tried the 'gently' bang several times on solid but carpeted floor (with camera off and lens retracted). Did the trick for me.
Solution #7
posted on Aug 27, 2007
Helpful)
jayfixit
Rank: Wiz
Rating: 89%, 87 votes
It sounds like a typical case of the focus motor gear being jammed, or out of alignment. The focus lens assembly is inside the lens, and if it doesn't move freely, the camera just retracts the lens, and shuts the camera off. I've fixed a few of these by removing the lens, taking the lens assembly apart, and getting the focus lens free again. The easiest way is to swap lens assemblies with another camera than maybe has a broken LCD. A little hint on these, is that the W100 has the same lens assembly as the less expensive DSC-W1. You can get those on eBay pretty cheap (~$35 with a good lens, but maybe bad LCD), and use it for it's lens.
Was this helpful?
Yes
No
Solution #8
posted on Aug 26, 2007
Somewhat Helpful)
Rado
Rank: Apprentice
Rating: 68%, 9 votes
Hello. Please turn off the camera and remove the batteries for 30 seconds (if this time don't solve the problem try with 1-2 minutes). Afterwards, reinsert the batteries and turn the camera back on. Perform a manual reset of the camera. For information on how to reset the camera please look at camera manuals. I hope this will help you :)
Was this helpful?
Yes
No
Solution #9
Somewhat Helpful)
Valiis
Rank: Wiz
Rating: 82%, 147 votes
I had a similar problem with a couple sony cameras at my business. I ended up calling Sony and they told me that the main board for the camera was probably damaged. They would be more than happy to look at it for 80 bucks, but would not guarantee that they could fix it.
I would give them a call and see what Sony says, you should have a phone number in your manual.
If it is going to cost more than 80-100 bucks to have them look at it I would just replace it.
Was this helpful?
Yes
No
Solution #10
posted on May 31, 2009
Very Helpful)
Bobby9Times
Rank: Guide
Rating: 100%, 1 votes
Took alot of dropping and banging but finally worked for me too. What I ended up doing was constantly rapping it with my knuckle very fast as it was opening and closing. Second set of doing that and bam, I've got a focus again.
Was this helpful?
Yes
No
Solution #11
posted on May 23, 2009
Very Helpful)
person0
Rank: Apprentice
Rating: 100%, 2 votes
HIT THE CAMERA! IT WORKS! all hope was almost gone, AND THEN I HIT IT!!!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #12
posted on Oct 01, 2008
Very Helpful)
ridenorm
Rank: Apprentice
Rating: 78%, 4 votes
I just read all the hitting and droping solutions suggested by those who had the same picture mode access problem I just experienced. I put a pocket calendar book on the coffee table, turned the camera top down and gave the top a quick, sharp rap against the soft surface of the calendar book. Like a dream come true my Sony W100 can take its wonderful pictures once again. Thanks to all you "rappers"! I firmly believe that Sony must recall these cameras and either fix the defect or give all of us who have experience frustration because of it a coupon for new 8.1 mega pixel camera.
Was this helpful?
Yes
No
Solution #13
posted on Apr 19, 2009
Somewhat Helpful)
adjr05
Rank: Apprentice
Rating: 75%, 1 votes
It is INCREDIBLE!! last night I was camping and some HUGE turtles came out to lay their eggs on the shore. I felt TOTALLY frustrated that my Sony cam was giving me the "Turn power off.." error and the lens where retracting and I couldn't even take a single picture because of that. So as soon as I arrived home from camping I looked for this problem on the web. And I just found this, of course I thought it was some kind of trick or something but it worked!!! I just hope to see the turtles laying their eggs again soon so I can take some pictures :(
Was this helpful?
Yes
No
Solution #14
posted on Jan 18, 2009
Somewhat Helpful)
kzh93
Rank: Apprentice
I had the same problem with my Sony W150. After hitting on the carpet and the top of the camera for a few times, it didn't work. I then hitted it at the bottom of the camera with my knuckle, it worked.
Thanks!
Was this helpful?
Yes
No
Solution #15
posted on Dec 05, 2009
Not Rated)
fud27
Rank: Apprentice
Rating: 0%, 0 votes
We opted to hit the camera against our desk on top of a pad. We hit it face down (lens side) but had the lens portion hanging over the edge. After a few hits the lens freed up and deployed. Thanks Sony!!
Was this helpful?
Yes
No
Solution #16
posted on Nov 04, 2009
Not Rated)
qtevie
Rank: Apprentice
Guys this is so freakin' hilarious! its 6am and I solved my camera problem in like 2seconds after reading suggestions!! i banged my camera twice not in a carpet but my bed. not in that kind of way..lol but it worked I was so happy...i ignored the error message for a week and I thought it was the memory card or battery...but not..TURN OFF AND TURN ON AGAIN message is GONE!!..like miracle..just freakin' slamming the camera twice in a soft object rofl!!!....I cannot believe the solution to the sort of digitechnical problem is fixable in seconds. Hahaha, i'm still laughin my ears off, I'm so happyyyyy I don't need to buy another camera..sony cybershot 7mp is a really great camera, been using it for 3years..first time this happened...now if it happens again, i know what to do. bang it! kk, peace everyone.!
Was this helpful?
Yes
No
Solution #17
posted on Oct 25, 2009
Not Rated)
jonathanhend
Rank: Guide
Rating: 88%, 3 votes
That is really odd. I've seen things like this for iPod. I have the manual for the camera and it mentions nothing of this. I could only imagine if this is what the sony store will do if I'd brought it in. You'd think they'd at least mention it in the manual. Oh well. The drop to the floor didn't help however a few taps on my palm on the side by the connecter has it booting like a top. Thanks for the adivce all.
Was this helpful?
Yes
No
Solution #18
posted on Oct 17, 2009
Not Rated)
vipco
Rank: Apprentice
Rating: 0%, 0 votes
Thanks guys...I guess sony also needs tapping...........the solution worked my DSC100.
Sailesh Fiji
Was this helpful?
Yes
No
Solution #19
posted on Aug 27, 2009
Not Rated)
SonyFix2
Rank: Apprentice
Rating: 0%, 0 votes
Too funny for words! I have Sony DSC-W120 and dropped it on the floor by accident. The same problem started happening, lense in and out and then the same error message, turn off and on. And while I could view photos already taken I could not take a picture. I figured the camera was finished. But I found this site and since I thought I had nothing to lose I followed the advice from the postings. I first hit the camera with my knuckles like Bliuuespoon25 (#4) posted but it did not work. So like Gapaeach (#5) suggested I used something a little heavier. It was actually a metal bolt about 3 inches long and 1/4 inch wide. I hit the top of the camera to the left of the power button a couple times while the lenses went in and out and OMG it worked! Too funny! But hey I just saved money! Thanks for the help!
Was this helpful?
Yes
No
Solution #20
posted on Jun 28, 2009
Not Rated)
bettivys
Rank: Apprentice
Rating: 0%, 0 votes
It took several times, but banging worked. The camera hurt my knuckles, so I used and old Microsoft Office 97 manual.
Was this helpful?
Yes
No
Solution #21
posted on May 20, 2009
Not Rated)
chichi004
Rank: Apprentice
Rating: 0%, 0 votes
Hi to all. I found out the solution here. At first, I laugh about the idea. But when I tried it, amazing. I can't believe it worked.
For those who have the same problem, you should have your charger near to you..
Here is the step by step procedure...
1. Put the battery in the charger for about 2secs.
2. Reinsert the battery in your camera.
3. Try to fall the camera in about 2-3feet in a carpeted floor. The camera lens should be facing the floor.
4. Try to press ON button and slide the ZOOM back and forth.
*If still nothing happens, start from step 1.
101% the camera will start working.
Was this helpful?
Yes
No
Solution #22
posted on May 18, 2009
Not Rated)
victor50
Rank: Apprentice
Rating: 0%, 0 votes
Gracias, el problema que tenia era "acceso" vuelva a encender la maquina".
Lo solucione como lo indicaron, con la maquina apagada y con el lente retraido, golpear en una alfombra suavemente con la base de la camara, solo con unos tres golpecitos fue suficiente. gracias a todos, excelente consejo.
Was this helpful?
Yes
No
Solution #23
posted on May 13, 2009
Not Rated)
mannysal
Rank: Apprentice
Rating: 0%, 0 votes
yes in did work now like a pro thanks a lot
Was this helpful?
Yes
No
Solution #24
posted on Sep 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
No F'n way~ I banged it as well and it worked! Ill be damned.
Solution #25
posted on Sep 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Not very big believers of knocking **** around either but GUESS WHAT!?!?!?!? One good tap on the desk and WAHBAM!!!!!!!!!! The thing works again!!!!!!!!!Thanks guys.........That's awesome.
Solution #26
posted on Sep 02, 2008
Not Rated)
Josefino
Rank: Apprentice
Rating: 0%, 0 votes
Thank God for this site, I have a W100 sony with the same problem ¨turn on and off again¨, the lens would expand and contract 2 or 3 times before getting that message, and i tried one of your solutions posted here..... I dropped my W100 camera from 2 to 3 feet onto a carpet , and about the fifth time i dropped it.... VOILA, the problem was all gone. Now i am a Happy Camper. Joe
Was this helpful?
Yes
No
Solution #27
posted on Apr 27, 2008
Not Rated)
tiziana
Rank: Apprentice
Rating: 0%, 0 votes
'guest' solution of september 2007 worked!!! Dear guest I believe you are from Sony, but when I contacted them they pretended not to know about thr problem ...I believe they should recall...anyhow banging gently the camera worked!
Was this helpful?
Yes
No
Solution #28
posted on Apr 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Today, I had the same error. I read above about Gapaech putting the camera in her purse. Well guess what, I did that today too. Sure enough the lens got jammed with the message everyone is saying.
Thankfully, I thought to troubleshoot and who would know that the solution is to hit the camera on the rug. It worked for me too! Thank you so much. My husband would have been so disappointed knowing that I carried it in my purse.
Solution #29
posted on Mar 09, 2008
Not Rated)
mototango
Rank: Apprentice
Rating: 0%, 0 votes
Sony Quality...?
This is the second Sony that I owned that needed repair.  After chuckling about the striking the camera I got frustrated and did it.  Well, It works.  The shock must help some mechanical function of the camera to engage.  The problem continues when power is recycled.  I was striking right where it says power on the unit.  The camera works fine...until powered off again. Thank you for your posts.  I'll be able to limp along until I find another brand camera to buy.  Sorry Sony, I've had it with your quality.   -mototango
Was this helpful?
Yes
No
Solution #30
posted on Mar 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
"I have turned it on and off over and over again! THANKFULLY I took "Guest's" advice from September 12, 2007. After hitting it a few times on the carpet, I still received the error, BUT while the lens was retracting in and out I hit the top of the camera beside the power button with my knuckle and it WORKED!!! I can take a picture again. Thanks so much for the advice. Hope this helps others"
It did work fine for me as well
Popular Solutions for Sony Cyber-shot DSC-W100
Questions and Unsolved Problems for Sony Cyber-shot DSC-W100
Do you recommend Sony Cyber-shot DSC-W100 Digital Camera?
Answer
Answer
it keeps telling me to turn off and turn back on. Can't take pictures
Answer
camera cannot turn on after connector cable was attached
Answer
I have a problem with my Sony Cyber Shot DSC-W100 digital camera. When I attempt to turn the power... (More)
Answer
Sony Cyber-shot DSC-W100 Digital Camera no any one butten working accept who photo takking botten
Answer
Sony cybershot dsc-w100 thumbwheel selector does not work properly and camera changes modes by... (More)
18 Other Users Have The Same Problem - Continued
Comment by Hani78, posted on Feb 12, 2009
TURN THE POWER OFF AND ON AGAIN MESSAGE
Comment by rzlatido, posted on Jan 31, 2009
I have the exact same problem!!!!! INCREDIBLE!
Camera does not acess and works after I hit it!!!!
Some one please send this page to SONY.
We all need our money back or something!!!!!
Comment by Guest, posted on Jan 25, 2009
I have the same problem, and I hit it with my hand. It worked for a day, and the problem happens again.
Comment by ridenorm, posted on Oct 01, 2008
When I power on, my Sony DSC-W100 screen says "Access", the lens goes in and out 3 times and then the screen says, "Turn the power off and on again". I can select viewing and see all the pictures I have taken, but I caannot get access and take pictures any longer. Does anybody have a solution to fix it, or to get Sony to recall this growing defect?
Comment by Guest, posted on Aug 13, 2008
Same problem as reported above "Turn the power off and on again" but still wont take any pictures! Lens moves in and out but never enters picture taking mode
Comment by tiziana, posted on Apr 22, 2008
Hi I have exacly tha sam problem. I bought the camera in Italy last year , so far it was ok but now same problem again as described. It says access, the display stays black, a yellow light on the corner turns on and off and the lenses move as if it is zooming, but nothing happens and it asys :shut down and restart!... Good to read that it is not a matter of battery, but does anybody know where I can bring to get it repaired???
Comment by Agiii, posted on Apr 14, 2008
Ok! Seriously I have the same problem with my camera.When i turn the camera on it says "Access" and then "Turn the power off and on again". What's up with that? hmm Do you guys think we could get free cameras from Sony?
Comment by Guest, posted on Mar 31, 2008
I have exacly the same problem.When i turn the camera on it says "Access" and then "Turn the power off and on again".
Comment by Guest, posted on Mar 25, 2008
i have a the same problem the power comes on the lens stays out and the camera goes off. i have to press the power on and off a few times to retract the lens. But still a blank screen please help as camera is 1 year old and the warrenty has just expired.
Comment by Whahooa, posted on Mar 21, 2008
Yep, the same error as above
Comment by Guest, posted on Dec 22, 2007
i have the same problem
Comment by tln6, posted on Nov 16, 2007
I am having the same problem with my camera. It will work fine for a few days but then when I go to turn it on every now and then an black screen saying access will come up the lense will telescope in and out a few times and then it will beep and say turn power off and on again. But after toogling the power the same thing happens. I am frustrated and looking for help.
Comment by kitchas, posted on Nov 12, 2007
I am getting the same error as above
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
