Question about Garden
Husky 3000 psi pressure washer troubleshooting
I need to know the location of the oil drain plug.
kuntrybaldgu
  • 7 Answers
SOURCE: I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
Posted on Jun 07, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
I have a Husky 3000 PSI - Was working fine (I think ( for about hours. All of a sudden it seemed to get a burst of energy and worked faster. Shut it off to add gas. When I started it up again, there...
Pressure washer are pretty simple, a few pistons and a spring device to control the pressure. The problem could be a broken part inside the pump itself. With any luck it could be the linkage between the pump and the motor. If there is a oil window in the pump or a pump oil fill plug open this and with the engine switched off slowly pull the starter cord and see if the pump works are moving. (don't do it fast or let the engine start or there will be oil everywhere.) this will tell you if the pump is working. It could also be the diverter this wold be harder to diagnose you could go and replace the whole pump also.
Aug 09, 2011 | Honda Pressure Washer PSI 3000
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Where do I look and what am I looking for when checking pump oil level . Honda / Husky 3200psi bought reconditioned from home store with out papers .
The pump oil reservoir and pump pistons are between the Honda engine and the business end of the pump. It rarely brass, like the pump. It may be square or tubular. Some of these units have a site tube on the side, some don't. Some have an oil drain plug (bottom) and a plug to put oil in (top). If not, you have to take the pump off. Either way, be sure to use NON-detergent oil and only fill it about 1/3 to 1/2 full.
Jun 10, 2009 | Honda Pressure Washer PSI 3000
Changing engine oil on a gx390 engine for pressure washer excel
On the very bottom of the motor is a square plug to drain the oil. The machine must be elevated to allow the oil to flow into a drain pan. If you don't see a square plug then look for a small 1/4 inch tube coming from the bottom of the crankcase with a hex cap on the end of it. If you cannot find either of these, then you must turn the pressure washer on its side and drain it through the same plug you fill from.
Apr 23, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
