Question about Home Security
Gigi door II
Remotes just stop working. The light on the remotes is working so the battery is ok. Everything else is working
ginko
  • 19396 Answers
SOURCE: craftsman 1/2 HP garage door opener, remote keypad stopped working
Try removing the battery and see if you can reset it.
Posted on Jun 01, 2008
SOURCE: Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Posted on Aug 08, 2008
  • 5 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
  • 905 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
Liftmaster garage door openers Model # 3245 (remote Issue)
it is possible that when you programmed the car remotes you erased the pairing between your hand held remotes and the unit. Follow the instructions to pair the remotes again and you should be good to go.
Sep 16, 2009 | liftmaster Chamberlain Garage Door Opener...
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not take code
If you just bought this remote you may have the wrong one for your unit.
Aug 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
All of a sudden all three remotes stopped working at the same time. Battery is okay, hard wire opener works
You probably have the lock enguaged on the opener. On the wall control, there is a button labeled "lock". Press and hold for 3 seconds and then release. the light on the wall button should be solid now. Your remotes should work. If the light is solid and the remotes still do not work, press the learn button on the back of the opener motor and then press the button on the remote. The light on the motor will blink once. Repeat on the other two remotes.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control
Try installing a pair of new alkaline batteries into the remote. If the problem persists, I would suspect the remote is defective and return it to the store for a refund. I have used Philips remotes twice before, and had problems with both of them. I switched to a One-for-All universal remote, and it has been trouble-free, so far.
Jul 05, 2008 | Philips 60P8341 60" Rear Projection...
Keyless Remote, Power Antenna, and Clock problem
have u tried under the dash a black box which is to alarm open it up there will be 2 pins there that u need to bridge with a flat screwdriver at the same time the blinkers should flash then press each of your remotes to programme them hope this helps
May 23, 2008 | 1999 Nissan Maxima
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
