I am looking for the lge23 switch power button cap
LCT2701ad switch on display logo ten off
Change input device to some other like a DVD player and see. Look for any loose contacts in power outlet, RC jack, cable or socket. Look for any jammed buttons on remote or on control panel.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT2715 27 in. LCD Television
When i boot up power button on monitor goes on off resulting in flickering picture.
hi look for a bulging or bad electrolytic capacitors in the PSU board which cause the output voltage drop, usually 1500 uf/ 16v.just replace those bad cap then it will resume to normal operation good luck thanks for consulting through fixya.
Jun 23, 2012 | Computers & Internet
Service manual for lge23
We require more information for this product. Is it a netbook or a TV? Have you searched on LG website they have manuals available there
Thank you
Mar 01, 2011 | Computers & Internet
TOSHIBA LCD TV. THE ON/OFF BUTTON WILL NOT WORK. WE CANNOT SWITCH ON THE TV
This is a common problem, inside the set the mains on/off switch has a small plactic cap on it which breaks easily - the power button externally is slightly off-set to the switch inside so this cap transfers the "push" at a slight angle - a new modified plastic cap with a stronger molding is now available from toshiba
Jan 03, 2011 | Televison & Video
Tv will not cut on 1st time you hit power you have to push power button many times before it will come on
Hello
The Power Switch is faulty and need to be replaced before it goes completely out of order.
Good Luck
Dec 10, 2010 | Samsung Televison & Video
Laptop not starting
you have problem with your keyboard replace your keyboard your problem will be solve
Apr 15, 2010 | Dell XPS M1330 Notebook
Hi My Fender Stage 100 DSP has a probem in that it doesnt always power up the first time you hit the off / on switch sometimes it takes two or three times before it turns on. It never has not turned on at...
It sounds like a power supply problem. If you can find the power supply board, look for bad solder joints, look for caps that might be bulging on the top, could be a leaky cap. I'm not sure of your power button, but it could be faulty.
Oct 22, 2009 | HHB Radius 50 Tube Amplifier
I have an LGE23 laptop .... i installed XP on it - windows does not see /find any bluetooth device ..... i have a new bluetooth mouse an my phones bluetooth is on so it should .... not sure what the...
i need all drivers of lge23 laptop with names plz send me.network vga.sound.wirless.camra.tuchpad.more what is their for used.mastermind_kw@hotmail.com
Jun 06, 2009 | Computers & Internet
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
