Question about Coffee Makers & Espresso Machines
Dismantle delonghi coffee machine en265 BAE
Machine has no power but frother still has power all power connections are working ie hot points cord is in good repair.
SOURCE: The power cord is hot but no lights or clock, nothing works.
I wish I had waited but I finished tearing the pot up and canned it. Next time I will know because I have ordered a new one.
Thanks; Stob
Posted on Jan 22, 2008
SOURCE: Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Posted on May 28, 2008
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
mcdevito75
  • 1970 Answers
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Posted on Jun 20, 2010
Delonghi Perfecta milk frother not heating.
My friend your problem is that the frother heat is foulty
Mar 18, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How can i fix the hot milk function on delonghi coffee machine?
The voice from the grinder ??
If so that's men you pushed the cappatino
Try to push the same button twice you will read
Further and steemar
Apr 06, 2015 | DeLonghi Magnifica Coffee Makers &...
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
Hi. My delonghi 3500 coffee machine is not able to froth milk. There is no water coming out of the hose. All water ending in the tray instead. Pushing hot water button the machine starts with a pumpin
I have a similar unit. One problem I had was a clogged solenoid for the frother. The solenoid is toward the front of my unit, connected to the frother by a hose. As I recall, I applied power to the solenoid and it did nothing. I figured it was clogged with minerals from hard water so I removed the solenoid from the machine, soaked it in vinegar, and tapped it a bunch of times to try loosen things up. Eventually, I could hear it engage when I applied power to it. I reinstalled it and the frother was working again.
Please note that the solenoids and pump inside the machine operate at full line voltage (e.g. 120VAC). Line voltage can hurt or even kill a person so you need to know what you're doing to work with it.
Sep 25, 2014 | DeLonghi ESAM3500 Espresso Machine &...
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi 3500s coffee machine not producing hot water or steam from water outlet/milk frother
Hey Everyone,
I had this exact same problem.
Check out my video of how to fix it.
Video: https://youtu.be/_SbGiD4LeCc
Hope it helps!
Jun 25, 2014 | Coffee Makers & Espresso Machines
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
