Question about Dishwashers
Whirpool adp 5000 dishwasher
Will not drain
5 Suggested Answers
SOURCE: WHIRPOOL DISHWASHER WILL NOT DRAIN
I had this problem too & found the discharge hose was clogged. To fix it I had to pull out the diswasher , disconnect the drain hose and blow it out.
Posted on Oct 05, 2008
jonniewalker
  • 1029 Answers
SOURCE: F8 error on ADP 5966 dishwasher after water cut
f8 shows the filter is blocked ... ... check if filter is behind the panel under the door ...
Posted on Oct 31, 2009
  • 500 Answers
SOURCE: In my dishwasher Whirpool ADP
Hi simone_b_630,
F7 is known as a fill fault.
1) Remove the filters and the mesh filter, clean out the black grid in the bowl carefully. Don't burst the membrane inside it.
2) Try the machine again after resetting it. (Reset it by holding the start button for 8 - 10 seconds)
3) If the fault persists, take off the left hand panel and unplug the flow-meter, located bottom front of the large plastic water matrix.
4) Plug it back on, reset the machine and try it again.
Also make sure the fill hose isn't kinked and that water is actually entering the machine.
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 19, 2011
caroldon
  • 17130 Answers
SOURCE: Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Posted on Sep 17, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Whirpool adp 2415
try turning off the power to the dishwasher for about 20mins then turn the power back on. sometimes this will reset the unit
May 21, 2014 | Whirlpool Dishwashers
Sep 17, 2011 | Whirlpool Dishwashers
We have an ADP 262 dishwasher and won't release some of the water
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 28, 2010 | Whirlpool Dishwashers
Whirlpool adp 5550
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Aug 29, 2010 | Dishwashers
Whirlpool dishwasher manual ADP 4549 WH
Hi If you ring +4420 8649 5000 Whirlpool uk ltd they aer very helpfull
Mar 22, 2010 | Dishwashers
Oct 31, 2009 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
ADP 4502/5 not working,not draining water,start
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 13, 2009 | Dishwashers
Mar 24, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
