Question about Sony XPlod CD Player w/MP3 Playback CDX-GT40W
NO SUB OUTPUT
My Sony XPLOD Model CDX-GT40W has no sub power. I connecte a bass tube to the sub connection (SUB Mono out) and get nothing. Any advise?
  • raymar1230 Apr 11, 2009
    i have the same problem but only in a mode other than tuner my amp shuts off like the stereo shut off, but in tuner it works great??? stumped
  • 27 Answers
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Posted on Mar 18, 2008
SOURCE:
How to use the Sub out feature on a sony car radio
You'd connect it, via RCA cables, to the amplifier that's driving your subwoofer (or to a powered subwoofer system).
Jul 13, 2015 | Sony Car Audio & Video
Hi I have just bought a Sony 820av amp and tannoy sfx speakers. I have got all working except my sub. Can anyone advise me on correct cabling for the sub to amp?
Sub woofers are just mono amps. They feed both the right and left output together. So all you need is a stereo to mono cable. The two jacks go in the sub and the single mono into one of the terminals on your amp. The other terminal will allow another sub to be connected I think, though please check your manual for this.
Jan 17, 2013 | Audio Players & Recorders
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
My iphone asks for a four digit code to pair as a bluetooth device with my sony xplod, how do i enter the 4 digit code into my sony xplod?
You enter a code on the source device, enter the code again on the head unit (using the remote control is the easiest way to do so), and the two devices connect.
Mar 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Changing faceplate colors.
only the display changes colors.... your deck is doing what it was designed to do!
Mar 18, 2008 | Sony XPlod CD Player w/MP3 Playback...
Help ASAP Plaese
Are you saying you connected the sony output jacks to your subs directly without any other amp? Are the sub outputs powered? Or line level? Are the subs powered or direct? need some more info please. and post the Manual here if you can. Thanks
Jun 14, 2006 | Sony CDX-M850MP CD Player
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Logo
398 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
