Question about Cfm 2000 Swamp Air Cooler MMB10 MasterCool Mobile Air Conditioner
MASTER COOL MODEL MMB10A problem
My evaporative cooler star to work but in few minutes stop working..any idea why? thx
Master cool not cooling. Outside air is dry and temp between 100 and 108. Fan working, water pump working. Water pan is full. Water flowing to top of padPad gets wet but only lightly. Air from cooler...
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Jun 28, 2011 | Heating & Cooling
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Stopped cooling compressor warm to touch
Feel the condenser on the side to if its warm top to bottom. If It's warm good if it's cool bad it's out of gas. That means leak in the system. If there is a leak, a new box may be cheaper than to fix it. If it is warm check the evaporator and evaporator fan. Make sure the fan is working and the evap-coil is not frozen.
I hope this helps.
Aug 23, 2010 | Haier BC112G Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
The Mastercool cooler is not cooling. It is only
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Jul 11, 2009 | Speed Port-A-Cool 16" Evaporative Cooler...
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water on the squiral cage side I don't know where its coming from
I don't know exactly what you mean by getting water on the dry side of the compartment. In any event, as you will see, there are very few sites that are dedicated to the maintenance and repair of evaporative coolers--you, in fact, submitted this problem of yours under the Air Conditioner section because there is no Evaporative Cooler section.
Having said this, I offer you two things: 1) a site that has a section dedicated to evaporative coolers, which took me a long time to find for my own problems:
and 2) the general idea that if you have water where it is not supposed to be, it likely is because there is a hole---obviously caused by rust--that allowed such water to get penetrated through. See more on rust holes of coolers here:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Has_Holes.htm
This should help get you on your way.
Brad
Jun 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
20 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
