Question about Refrigerators
My whirlpool model# ev205nxtn freezer cools to 62 degrees
My whirlpool model # ev205nxrn 01 does not freeze it only goes to 62 degrees
  • 1122 Answers
SOURCE: fridge was in storage 4months fan work but not freezing.
is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
  • 51 Answers
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
  • 22 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Posted on Apr 25, 2009
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
1998 GT22DKXGN00 refrigerator freezes, where is thermostat in refrigerator ? This is a Whirlpool
Check refrigerator and freezer temperature. If the freezer is above 0 degrees Fahrenheit it is likely the cooling capacity of the unit has reduced due to low charge or weak compressor. What usually happens is that the freezer is not able to reach the proper temperature and the unit runs continuously. The result is that the refrigerator via the freezer-refrigerator air flow connection freezes.
"This is not intuitive", but the logic is that from the compressor running continuously the freezing air that flows into the refrigerator side results in that the refrigerator will freeze,.
Check the temperatures. If the freezer is above 10 degrees F it is almost certianty the cooling capacity has been reduced.
If equipped with an ice maker the output of the ice-maker will also reduce with this problem
It is possible to have the compressor replaced but not usually cost effective.
Apr 10, 2017 | Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Freezer freezes, but refrigerator section will no get beow 55 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool fridge model GD5YHAXTL 01 gets too cold. Milk is freezing. So far I have cleaned it out and it is currently unplugged.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool Refrigerators
Water drains from freezer compartment into refridgerator
Jan 09, 2009 | Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
