Question about Nikon Coolpix S4000 Digital Camera
When I turn the camera on, it says lens error and shuts off
The camera will come on and lens opens and then immediately closes and displays lens error.
  • 3 Answers
SOURCE: Lens Error!
Hi I use to be a camera technican for samsung repairing small camera's like yours.It is a very common fault 90% unfortunatley of lens errors are the users fault not the cameras. The lens error means the lens is jammed, usually by a slight knock while the lens is out or a bit if debri like sand getting into the lens's moving parts. If it is still under manufacturers warranty send it in for repair. If the camera is clean and looked after with no scratches, dints or abrasions on the lens or camera body you will have a chance to get it fixed under warranty for free. If it is scratched and dinted and the purchase value of the camera is around $250 it may cost you around that to get it fixed. Good luck
Posted on Jan 12, 2009
SOURCE: lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
Posted on May 13, 2009
  • 11967 Answers
SOURCE: nikon coolpix s230 lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 19, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Posted on Apr 23, 2010
  • 11967 Answers
SOURCE: Nikon l3 lens error
Posted on Jul 01, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
How do I fix "lens error" problem described below?
usually caused by particles in the lens advance and retraction mechanism.may need cleaning by expert.but first try to GENTLY pull the advanced lense out up to fully out position.note the word GENTLY,otherwise the camera will be ruined.
New S5100 Nikon coolpix 12 mpx lens error . It opens then closes immediately and says lens error on screen . what to do??
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 22, 2011 | Nikon COOLPIX S5100 Digital Camera
Everytime I turn on my Nikon Coolpix camera it says lens error and I do not know why.
something is blocking the lens to get out ..and the camera can not start ..and it displays the error and close...try to see if something or maybe just the usage under poor conditions like rain or sand ..caused the lens not to open proper..sometimes weak batteries can not action-ate the lens gear ..and the error is on also ...
Aug 02, 2010 | Cameras
My coolpix displays lens error when it is turned on. The lens opens and closes twice before the display reads lens error.
his generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Jul 15, 2009 | Nikon Cameras
Digital camera defect.
the focus lens inside lens assembly is out of time . will not fully power on till lens assembly is replaced.
Apr 16, 2009 | Cameras
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon Coolpix S4000 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
