TRANE MODEL NUMBER BTR730E100A0
HOW TO OIL MOTOR
Trane model number thh150. how much it costs?
That model is for an RV/Motorhome. Trane no longer makes it. A replacement unit is about 700 USD
Jul 31, 2017 | Heating & Cooling
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
Jul 14, 2017 | American Standard Heating & Cooling
Trane XL 1100 igniter. What is the model number for the XL 1100
Please contact Trane customer service on this part number.
Dec 05, 2016 | Heating & Cooling
What type and size condensor fan goes in a 2 ton split system?
depends on the manufacturer. go to manufacturer internet site with model and serial numbers for parts info. if you are talking about a system other than rheem,trane,lennox. it is usually in the 1050 rpm, 220 volt,1/3 hp and you could use a rescue motor to replace it with. reversible motor.
Oct 11, 2015 | Heating & Cooling
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Nov 15, 2007 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
