Question about Husqvarna 128DJX Split Shaft Beam Trimmer
What is the gas/oil mixture for a husqvarna 128djx trimmer ?
  • 120 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
  • 42 Answers
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the ratio of oil and gas mixture for
Find an Operators and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 07, 2009
dontbother10
  • 2220 Answers
SOURCE: It Won't Start
Read your manual very carefully. I think it is flooded. Read line 3 (cold and warm). read them again. Read 5 in your manual. Most overlook the attempt to start , continue with the choke closed and the saw floods. You have an additional visual indicator, watch the decompression valve, when cold; once it pops turn off the choke. The warm procedure is very close to mine.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If it still will not start return it for a replacement or your money back. Anything you do may render any warranty invalid.
Did you purchase this in a big box store? What is your elevation?
All new saws regardless of maker are set to run extremely lean to meet EPA mandated air quality standards. They are also fitted with a device to restrict richening the carburetor beyond initial factory settings this too required by the EPA. Most big box stores put them on the shelf and sell them to the consumer with no thought of how elevation may impact saw performance or longevity. Homeowners usually are not concerned about changes in the saws performance until it quits operating. This combination results in many destroyed saws and homeowner saws of most brands being called trash!
Find a local chainsaw seller/mechanic. If they pull a saw off the shelf and hand it to you without making some adjustment or minimally ensuring it will run hand it back and leave. You can get this service at a big box store cheaper. Find a different seller/mechanic and try again. A good dealer will help you arrive at a saw that will meet your needs. He will ensure it runs properly and you have an understanding of how to properly operate it. Should a problem arise you have somewhere to go and if you were courteous with your dealer someone in your corner helping you rectify your problem.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 08, 2010
SOURCE: what is the oil/gas mixture ratio for the
should be stamped on fuel cap
Posted on Apr 15, 2010
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
Husqvarna problems
This unit has had some issues with the drive shaft coming out of the clutch drum. make sure the drive shaft fully fits into the clutch drum.
Aug 02, 2014 | Husqvarna 128DJX Split Shaft Beam Trimmer
Does the 28cc and 25cc weedeater use the same oil and gas mixture
Yes they will use the same mixture, it doesn't matter on the size of the engine. I would recommend using a 50:1 ratio. That equals out to 2.6 oz of oil per gallon of gasoline. Hope this helps, Daniel.
Oct 26, 2011 | Husqvarna 28cc Gas Line Trimmer
How much oil do I use per 1gallon of gas for a Husqvarna 223L weed eater?
for a 40/1 mixture use 3 ounces of oil ( 2 stroke) to a gallon of gas for a 50/1 ( which is what I recommend ) its 2.5 ounces to each gallon of gas, if you find that the machine is smoking a little too much,, back up on the oil just a hair,, but I don't think you'll need to
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
What is the gas/oil mix for my Husqvarna grass trimmer 225r
hi mem0404...
Use a 50:1 mixture with your trimmer.
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 15, 2011 | Husqvarna 28cc Gas Line Trimmer
What is the oil to gas ratio for the husqvarna 125l weed eater
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Hi im after the fuel mixture for a 125L husqvarna straight shaft brush cutter.thanks
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
HTH
Lou
Jan 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
GAS COMES OUT OF MUFFLER WHENI TRY TO START IT
check your oil/gas mixture and make sure your spark plug is clean and fairly new. Also be sure the air outlet isn't blocked by debris.
Jun 11, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 128DJX Split Shaft Beam Trimmer Logo
73 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
