Question about SVA-USA VR2018 20 in. EDTV-Ready LCD Television
Remote channel input
The keypad on the remote will not accept double digit channels. I have to use the channel up button.
  • kfunk Aug 27, 2007
    I tried that and it didn't work....but thanks. It is a new tv so I would have been surprised if it was dirty......
    I think it is a programming thing
    thanks for your help
    Scholar:
  • 72 Answers
Try taking the remote apart with a screwdriver and cleaning the board with a cue tip and some rubbing alcohol. That usually works on mine when that happens.
Posted on Aug 26, 2007
  • Anonymous Aug 27, 2007
    Other thing you can try is if you happen to have a universal remote laying around, try programming it to see if the remote works.
    If you get the universal one working, and the buttons work, you know its not a problem with the tv, just the remote.
    Might give you an idea wiether or not you want to return it
SOURCE:
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Lost the remote to my tv, and my remote can't get the tv off the video input channel, is there a way to reset the tv, the input button and/or menu button on the tv won't change the channel either
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Without a remote control; you can't adjust anything with this TV
Jul 29, 2015 | Televison & Video
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
Mar 12, 2015 | RCA (DTA800B1) Video Converter
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
How do we change a channel to accept VHF
You can use the remote and push the input button until it shows digital channel. But in order to get VHF you need the access the channel search in menu. You also will need a descent "digital" antenna as the Digital signal is no where near as relaible as analog was. Also older antanna's do not seem to work very well with the digital signal. I recommend an outdoor version because a single wall can interfere with digital signal. If thats not an option get a descent amplified indoor antenna. If you do a channel search without an antenna more than likely you not find any channels.
Dec 14, 2010 | Samsung Televison & Video
Not able to get the auxillary channel. I know to channel down but it does from 1 to 125. I've tried the preset channels again - it doesn't show. Game is on. I have the remote. Any suggestions?
It's possible that the AUX channel was erased from the display menu. Go to your CHANNEL SET menu choice and and use your DOWN CHANNEL button to see if the AUX channel will come back.
Mar 06, 2010 | Sylvania SST4322 32" TV
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Oct 27, 2009 | Samsung TV Remote Control
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
SVA-USA VR2018 20 in. EDTV-Ready LCD Television Logo
49 people viewed this question
Top SVA-USA Televison & Video Experts
Steve Allison
Steve Allison
Marvin
Marvin
Vitally Alcher
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
