Question about Premier Super G 3 Jar Kitchen Machine Mixer Grinder 110 Volts / Premi
Premier super g mixer grinder not working
Motor not working properly flame is coming
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
I want to know how does an overload switch works in mixer grinder
when the motor get stuck it cuts the power to the motor. some models you have to reset by hand. means opening up the unit and taking out what has blocked it in the first place. but there is a thermal switch in the motor and if it overheats it blows this. and you will either need to get another motor. cut the wires back on the motor to get to it but doing this can be dangerous and you can blow the hole unit up and you don't want to do this when you are in front of it can cause death.
Apr 12, 2013 | Preethi Nitro Mixer Grinder - 110 Volts...
I cannot grind cranberries through the grinder attachment for a Kitchenaid stand mixer. The grinder is turning but I have to use every ounce of strength to push the berries down the chute and I never had...
Hello, Please check your grinder's output end and verify that it is assembled properly and using the correct grate as it seems that your grinder is all jammed up at that end and will cause the input area to back up so you have to push harder to force it to work correctly. Good Luck! -Rich
Nov 24, 2010 | KitchenAid FGA Food Grinder attachment for...
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Hello. My Mazzer grinder doser Super Jolly (used
It could be that the switch failed, try this to check remove the top part or the grinder burrs and turn it on, if it turns then, grinder was jammed if not switch needs to be replaced.
Apr 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My Super Grinder needs repairs
the blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Feb 02, 2009 | Food Mixers
Hi,wken i switch on my panasonic mixer grinder ,fire is coming it looks ike something is burning inside .Could u please let me know what happened?
What is a Panasonic Mixer Grinder?
What model?
If there is fire, and it smells like burning, DO NOT DO ANYTHING BUT POWER OFF and UNPLUG THE UNIT. You'll need professional help at this point. Something is obviously burnt inside.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Oct 01, 2008 | Pioneer DJM-600 Silver Professional DJ...
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Premier Super G 3 Jar Kitchen Machine Mixer Grinder 110 Volts / Premi Logo
Top Premier Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Premier Saw Expert? Answer questions, earn points and help others
