Question about Cell Phones
Samsung S5511T reset T9 dictionary
I want to get rid of the misspelled words in my T9 dictionary. when I go to Settings, and choose phone settings, it comes up with a phone lock and new password. I dont want a password on my phone, how do I avoid?
SOURCE: Reset the T9 text dictionary
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Posted on Oct 10, 2008
SOURCE: Samsung sgh-e370 default password
Hi.
The default password is : 00000000 (8x0).
Hope it sorts your problem for you!
Posted on Oct 20, 2008
izzy1968
  • 6 Answers
SOURCE: Predictive text
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Posted on Dec 08, 2008
izzy1968
  • 6 Answers
SOURCE: Samsung SGH-c225 predictive text malfunction
If you have accidentally saved a word into the T9 dictionary (ie, "IS" comes up with "47" or "Get" comes up with "HDU", you can teach the dictionary to revert back to the original word.
What you have to do is..... create a new text message, enter the text that is annoying, (ie, "IS"). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again - you can do this in the same text message - it can take up to 20 goes but eventually, the dictionary recognises that you actually wanted "IS".
Posted on Dec 09, 2008
SOURCE: dictionary language for text messages changed
i was having a similar problem, if you go into a message and then press down the bottom where you would change the keyboard/input type (Samsung Keyboard, Samsung Phonepad ect.) > select Options....... >Input method tab > options > select English from the drop box > check that the XT9 Settings is also set to English. I hope this fixes the problem for other people with the same issue
Posted on Jun 12, 2009
How to remove misspelled words from dictionary of Samsung Gt-s5300 I have successfully deleted misspelled words from the XT9 my words list, but they still reappear as options when I'm typing a text...
you don't need to remove it, you need to deactivate it in the settings because tapping it by mistake automatically activates the feature.
Sep 23, 2013 | Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do i delete words that have been added to the dictionary on the tocco ultra
You can't delete other than by reflashing the phone or some phone RESETS will reset the dictionary You can however "lower" the word you want to ignore in the T9 word option list.
This is done by typing the same letters as the word you dont like such as "WOT "and repeatedly replacing ( i,e. choosing it from the options) it with the word you do want say "YOU".
So start an SMS message in T9 mode and repeatedly type "wot" and replace it with "you"
you you you you you you you you................
save the message in drafts
start a new message in abc mode the type
save to drafts..........
start a new message in T9 mode and Viola - "you" should be above "wot" in the word option list.
The T9 dictionary has "learned" your preference.
Regards.........B
Aug 02, 2010 | Cell Phones
How can I erase a word from the T9 database?
You cannot delete a word from the T9 database. If you add lots more words with the same combination, then over time the word is erased. Or you could reset your phone's settings and data. You would lose all your contacts and messages and everything, but even the dictionary will be reset.
May 16, 2010 | Casio G'zOne Boulder Cell Phone
How do I edit the dictionary on my samsung tocco ultra. I type 'is' and get GP, for 'the' I get Vid. Driving me crazy how do I delete these? thanks
Not a solution same problem. If I type "is" I get 4M suggested. If I type "of" I get Nd suggested. Driving me nuts !!
Jan 02, 2010 | Cell Phones
T9 Dictionary on Samsung SGH-A707
The only way to fix this is to completely reset your message memory. To do this, go to Menu -> Settings -> Memory Settings -> Clear Memory -> then click Messaging and OK. You will be prompted to enter your password. Enter it, confirm and you should have no problems.
Feb 24, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Nov 13, 2008 | Samsung SGH-c225
Predictive text
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Sep 25, 2008 | Samsung SGH-a737 Cellular Phone
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
