Question about Flotec Plumbing
Pump body and bracket position bolt mount repair.
Hi, I was installing new 4032-10 pump. I wanted to put the pump on a wooden base, so I removed the two bottom bolts so I could mark position on the wood with just the base. All was good or so I thought, after assembly, then priming, water came out the bottom of the pump, so I tightened the bolts a little more not too tightly. All was fine apart from the water pressure would drop sometimes. Tank side pressure read 50psi / pump would go up to 45psi. but would drop to below 15psi. I think I need too check these gauges. Returning home, the pump was running, water gushing out, the pump body had come away literally pulling the mounts on the plastic pump body about half an inch out. My questions are; Does the base go between the pump body and motor or does it sit on the bolt head side? Also I have only been using it for a week and the pressure seemed good but would drop and it would not engage unless I flicked manually would this be due to the foot valve or is it the pressure tank lacking air? I think I will have to order a new pump body unless I could get a strong glue to put back the bolt mounts in place ? Any ideas on this? save $$$. But I'd like to check it's not something other than me putting either the base in the wrong place (at head of bolt side is where I put it.) which I'm sure was right as with other pumps? Or I have just done them too tightly and they just gave way as they are in bedded plastic? I would be grateful for advice as I live on a remote island no plumper shops here! cheers.
    Sergeant:
  • 278 Answers
Lol too much power for the pressure tank back off the flow or get a new pressure valve 50 psi is good pressure how big is the tank what is the gauge rated for all these \details need to be spoken in order to answer sounds like you want some water lol its sucking air too tank doesn't need air it has to be primed first tighten the bolt and now you have to use pipe sealant white putty to seal those nuts and bolts back up pump cant suck air
Posted on Mar 07, 2017
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
mechanicm639
  • 253 Answers
SOURCE: 1999 Buick Park Avenue water pump removal
The bolt holding you up is on the bottom by the compressor, right? You Will have to have an inverted torx socket to remove the studs. Also there is a spacer behind the mount bracket, remember where it goes. You will have to pull the pully bolts and get it out of the way too. Some of those cars have plastic elbows going from the intake to the water pump, be carefull with it. Your motor may not have this but be ready to replace it if it does because it will most likley break. Good Luck.
Posted on May 10, 2009
  • 401 Answers
SOURCE: 1999 Buick Park Avenue Water Pump Removal
Hi once you have all the bolts off for the mount raise the front of the motor up till you can remove the center part of the mount
I use a floor jack and a 2x4 across the oil pan then remove the studs for the motor mount bracket now remove the bracket and now you can get the water pump out
hope this helps
emissionwiz
  • 75235 Answers
SOURCE: how do i remove the power steering pump from a
u need to get a special tool for pulling asnd installing the pump's pulley, as soon as you get the pulley off the pump is easy to remove, Autozone and Kragen loan this tool with acredit card secrity deposit.
Posted on Jul 26, 2009
SOURCE: Cabin pump, primed fine only goes to28psi and keeps running
Sounds like the injector nozzle is plugged. This nozzle is directly inside the influent line on single line jets and down in the well on two-line jets. I'm assuming you have it primed correctly. If this happened suddenly the it'd definitely the injector nozzle. It it was a gradual process over time then I would say it's either a badly worn nozzle or worn impeller.
Posted on Sep 08, 2009
Flotec 1 hp fp4032-10 Bracket position/bolt mounts
como poner en tiempo un cadila escalade 1999
Jul 10, 2013 | Cars & Trucks
Water pump 2000 3.0 liter dodge caravan
For The 3.0 Motor. (3.3 Way down the line.)
Drain cooling system.
Remove timing belt. Refer to Engine for procedure.
Remove water pump mounting bolts.
Separate pump from water inlet pipe and remove water pump.
Timing Belt Removal
Raise vehicle and remove accessory drive belt splash shield (Fig. 66).
Remove accessory drive belts.
Remove crankshaft pulley and damper (Fig. 68).
Support engine and remove right side engine mount.
Remove engine support bracket (Fig. 67).
Remove timing belt covers (Fig. 67).
Mark belt running direction for installation (Fig. 69).
Loosen timing belt tensioner bolt (Fig. 71) and remove timing belt.
Remove crankshaft sprocket flange shield (Fig. 68). CAMSHAFT SPROCKETS To remove camshaft sprockets
Hold camshaft sprocket with Spanner Tool MB-990775. Loosen and remove bolt and washer (Fig. 70).
Remove camshaft sprocket from camshaft. To install camshaft sprockets:
Place camshaft sprocket on camshaft.
Install bolt and washer to camshaft. Using Spanner Tool MB-990775, hold camshaft sprocket and torque bolt to 95 Nm (70 ft. lbs.) (Fig. 70). TIMING BELT TENSIONER
Install timing belt tensioner and tensioner spring.
Hook spring upper end to water pump pin and lower end to tensioner bracket with hook out (Fig. 71).
Turn timing belt tensioner counterclockwise full travel in adjustment slot and tighten bolt to temporarily hold this position (Fig. 72).
INSTALLATION
Install timing belt on crankshaft sprocket and keep belt tight on tension side (Fig. 69). Install belt on the front (radiator side) camshaft sprocket. Install belt on the water pump pulley, rear camshaft sprocket and finally on the timing belt tensioner.
Rotate the front camshaft sprocket in opposite direction to take up belt slack. Check that all timing marks are aligned (Fig. 69).
Install crankshaft sprocket flange (Fig. 68).
Loosen tensioner bolt and allow spring to tension timing belt.
Turn crankshaft two full turns in clockwise direction. Turn smoothly and in clockwise direction ONLY.
Align the timing marks on the sprockets and tighten the timing belt tensioner locking bolt to 28 Nm (250 in. lbs.) torque.
Install timing belt covers.
Install engine support bracket.
Install right side engine mount.
Install crankshaft damper and pulleys (Fig. 68). Tighten damper center bolt to 135 Nm (100 ft. lbs.) .
Install accessory drive belts.
Install accessory drive belt splash shield (Fig. 66).
Be sure to also replace all the cam and crank seals why you are there. Might as well put a belt on too.
FOR THE 3.3 OR 3.8 MOTORS.
Drain Cooling System.
Remove accessory drive belt.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws. Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface
Installation
Install new O-ring into groove.
Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
Install accessory drive belt.
Install right front lower fender shield.
Refill Cooling System.
FOR THE 2.4 MOTOR
Disconnect negative cable from battery.
Raise vehicle on a hoist. Remove right inner splash shield.
Support engine from the bottom and remove right engine mount.
Remove right engine mount bracket.
Remove timing belt idler pulley.
Hold camshaft sprocket with Special tool C-4687 and adaptor C-4687-1 while removing bolt. Remove both cam sprockets.
Remove rear timing belt cover.
Install new O-ring gasket in water pump body O-ring groove. CAUTION: Make sure O-ring is properly seated in water pump groove before tightening screws. An improperly located O-ring may cause damage to the O-ring and cause a coolant leak.
Assemble pump body to block and tighten screws to 12 Nm (105 inch lbs.) . Pressurize cooling system to 15 psi with pressure tester and check water pump shaft seal and O-ring for leaks.
Install rear timing belt cover.
Install camshaft sprockets and torque bolts to 101 Nm (75 ft. lbs.) .
Install timing belt idler pulley and torque mounting bolt to 61 Nm (45 ft. lbs.) .
Install timing belt. Refer to Engine for procedure.
Install right engine mount bracket and engine mount. Refer to Engine for procedure.
Fill cooling system.
Lower vehicle and connect battery cable.
Mar 29, 2012 | Cars & Trucks
How to change a crank position sensor on 2006 suzuki forenza
5) Install the rear A/C mountingbracket. Tighten the rear A/C mounting bracket bolts to 35 Nm (26lb-ft).6) Install the A/C compressor. 7) Install the power steering pump. 8) Connect the negative battery cable.12_16_2011_6_00_05_pm.jpg
If this helps, please say so! Thanks! :-)
Dec 08, 2011 | 2006 Suzuki Forenza
Location of "starter" for 1999 cadillac catera
Hi, if you have the 3.0 liter engine, see instructions below. If you have the 4.6 liter, the starter is under the intake manifold.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Starter electrical connectors Right hand catalytic converter Right side engine mount nuts Intake air resonator to the throttle body ducts
  3. Install an Engine Support Fixture to the right side of the engine.
  4. Raise the right side of the engine approximately 1.5 inches (38mm) to gain access to the starter motor bolts.
  5. Remove or disconnect the following:
    Engine mount from the bracket and cradle Engine mount bracket bolts and reposition the bracket Starter motor
    Fig. Remove the starter motor and bolts
To install:
  1. Install or connect the following:
    Starter motor. Torque the bolts to 44 ft. lbs. (60 Nm). Engine mount to the bracket and front crossmember. Torque the bolts to 30 ft. lbs. (40 Nm).
  2. Lower the engine into position and make certain that the mount locator tab is fully seated in the front crossmember slot.
  3. Remove the special tools from the engine.
  4. Install or connect the following:
    Engine mount nuts. Torque the upper nut to 30 ft. lbs. (40 Nm) and the lower nut to 41 ft. lbs. (55 Nm). Intake air resonator to the throttle body ducts Catalytic converter. Torque the bolt to 25 ft. lbs. (34 Nm) and the nuts to 18 ft. lbs. (25 Nm). Starter electrical connectors. Torque the battery cable nut to 115 inch lbs. (13 Nm) and the starter solenoid nut to 35 inch lbs. (4 Nm). Negative battery cable
Oct 03, 2011 | Cars & Trucks
I want to know how to remove the alternator kia optima 2003
  1. Disconnect the negative battery cable.
  2. Temporarily loosen the water pump pulley bolts, 1.6L (VIN 3) engine only.
  3. Remove the front air intake inlet pipe bolts, 1.8L engine only.
  4. Remove the top hose from the air intake inlet pipe, 1.8L engine only.
  5. Remove the air intake inlet pipe clamp and the pipe, 1.8L engine only.
  6. Remove the power steering pump, 2.0L engine only.
  7. Remove the power steering pump bracket, 2.0L engine only.
  8. Remove the alternator B terminal cover cap.
  9. Disconnect the alternator electrical connections.
  10. Loosen, but do not remove the alternator pivot bolt and the tensioner mounting bolt.
  11. Remove the drive belt(s); relieve tension on the belt by rotating the adjustment bolt.
  12. Remove the water pump pulley, 1.6L (VIN 3) engine only.
  13. Remove the power steering pump, 1.6L (VIN 3) engine only.
  14. Remove the power steering pump bracket, 1.6L (VIN 3) engine only.
  15. Remove the alternator tensioner mounting bolt and the belt tensioner.
  16. Remove the alternator pivot bolt.
  17. Loosen the bolt at the base of the adjusting bracket and rotate the bracket up.
  18. Remove the alternator.
    Fig. Alternator mounting-1.5L and 1.6L (VIN 5) engine shown
    Fig. Alternator mounting-2.0L and 1.6L (VIN 3) engines shown
    Fig. Alternator mounting-2.4L and 2.7L engine
To install:
  2. Install the alternator.
  3. Install the alternator pivot bolt and hand-tighten at this time.
  4. Rotate the adjusting bracket into position, place the belt tensioner into position. Hand-tighten the mounting bolt.
  5. Install the drive belt.
  6. Adjust the belt tension by rotating the adjustment bolt.
  7. The belt deflection for 1.5L, 1.6L (VIN 5), 2.4L and 2.7L engines, is as follows:
    1. New belt: 0.22-0.28 in. (5.5-7mm).
    2. Used belt: 0.24-0.28 in. (6-7mm).
  8. The belt deflection for 1.6L (VIN 3) engine is as follows :
    1. New belt: 0.13-0.15 in. (3.3-3.7mm).
    2. Used belt: 0.17-0.19 in. (4.2-4.7mm).
  9. The belt deflection for the 2.0L engine, is as follows:
    1. New belt: 0.22-0.31 in. (5.5-8mm).
    2. Used belt: 0.33-0.45 in. (8.5-11.5mm).
  10. The belt deflection for the 1.8L engine, is as follows:
    1. New belt: 0.23-0.31 in. (6-8mm).
    2. Used belt: 0.28-0.35 in. (7-9mm).
  11. Tighten the tensioner bolt to 14-19 ft. lbs. (19-26 Nm) and the pivot bolt to 28-38 ft. lbs. (38-51 Nm).
  12. Connect the alternator electrical connections.
  13. Install the alternator B terminal cover cap.
  14. Install the power steering pump and adjust the power steering belt tension, 2.0L and 1.6L (VIN 3) engines only.
  15. Install the water pump pulley, 2006 1.6L engine only.
  16. Install the air intake inlet pipe and fasten the clamp, 1.8L engine only.
  17. Install the top hose to the air intake inlet pipe, 1.8L engine only.
  18. Install the front air intake inlet pipe bolts, 1.8L engine only.
  19. Connect the negative battery cable.
Feb 09, 2011 | 2003 Kia Optima
How do i replace a water pump on a 1997 vw passat
Water Pump REMOVAL & INSTALLATION 1.8L Engine NOTE: The coolant pump is bolted to the brackets for the generator, power steering pump, and cooling fan.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Position the lock carrier into the service position as follows:
    1. Remove or disconnect:
      • Front bumper.
      • Any wiring or connector that would inhibit locking the carrier.
      • 3 quick-release screws on the front noise insulation panel.
      • Air guide between the lock carrier and the air filter.
      • Retaining clamps for the wiring harness at the left side of the radiator frame.
      • No. 2 bolts and install Support tool 3369 or equivalent.
      • Remaining bolts and pull the lock carrier out to the stop.
    2. To secure the lock carrier, install the appropriate M6 bolts into the rear of the lock carrier and fender.
  3. Remove or disconnect
    • Negative battery cable.
    • Accessory drive belt, then the engine driven cooling fan.
    • Coolant.
    • Clamps for the coolant hoses at the water pump.
    • Intake air duct between the intake manifold and the charge air cooler.
    • Generator mounting bolts and slide it forward.
    • Wiring from the generator once it is removed.
  4. Unbolt the following supports and brackets for the generator, power steering pump, and engine cooling fan:
    1. Intake manifold support
    2. Support for the engine torque bracket
    3. Brace to the cylinder block (remove completely)
  5. Remove or disconnect:
    • Brackets for the generator, power steering pump, and engine cooling fan, positioning the brackets to the left side using a piece of wire
    • Coolant hoses from the pump and thermostat housing
    • Coolant pump housing from the timing belt cover
    • Coolant pump mounting bolts, then the pump
    • Impeller housing from the pump housing
    To install: Fig. 1: Exploded view of the water pump, housing and related components — 1.8L engine 9301wg04.gif
    Fig. 2: Assembly bracket with water pump mounting bolt tightening sequence — 1.8L engine 9301wg05.gif
  6. Using a new gasket, mount the new coolant pump to the pump housing. Mounting bolts: 84 inch lbs. (10 Nm).
  7. Using a new gasket and O-ring, install the coolant pump. Mounting bolts in alphabetical sequence: 18 ft. lbs. (25 Nm).
  8. Tighten the coolant pump housing to the timing belt cover to 84 inch lbs. (10 Nm).
  9. Install or connect:
    • Coolant hoses to the pump and thermostat housing.
    • Brackets that were removed. Mounting bolts: 18 ft. lbs. (25 Nm).
    • Wires to the generator, then install the generator.
    • Air intake duct between the intake manifold and the charge air cooler.
  10. The remaining steps are the reverse of the removal.
  11. Fill the engine with coolant
  12. Fully close all power windows to stop, operate all window switches for at least 1 second in the close direction to activate the one-touch opening/closing function
  13. After installing the lock carrier, check the wiring for proper routing near the cooling fan
Aug 11, 2010 | 1997 Volkswagen Passat
How do i replace a water pump on a 1992 buick lesabre custom
GM Bonneville/Eighty Eight/LeSabre 1986-1999 Water Pump - REMOVAL & INSTALLATION
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
1987-95 Vehicles
EXCEPT 1995 VIN 1 ENGINE
  2. Drain cooling system into a suitable container.
  3. Remove the serpentine drive belt, as outlined in of this repair guide.
On some engines, removing the alternator provides better clearance for removing the water pump. For alternator removal and installation procedures, please refer toin this repair guide.
  1. Unfasten the water pump pulley bolts, (long bolt removed through access hole provided in the body side rail), then remove the pulley.
  1. Disconnect the radiator and heater hoses from water pump.
  1. For 1992-95 vehicles, remove the torque axis mount, as follows:
    1. Use a suitable engine support fixture and lifting bracket to raise the engine slightly to take the weight off of the engine mounts.
    2. Remove the through-bolt from the torque axis (front) engine mount.
    3. Lift the engine with the support fixture until the power steering reservoir touches the strut tower cross brace.
    4. Loosen the bottom two bolts on the torque axis (front) engine mount.
    5. Remove the A/C line clip and top two bolts on the torque axis engine mount, then remove the mount.
    6. Remove the 2 bolts and nut attaching the engine torque axis mount bracket assembly to the front of the engine.
On some engines, when you remove the 13mm bolts, coolant will flow from the bolt holes, so make sure to position a drain pan under the pump before unfastening the bolts.
  1. Remove the water pump attaching bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean the gasket mating surfaces.
To install:
  1. Apply a suitable sealant to the bolt threads.
  1. Position a new gasket, then install the water pump to the engine and tighten the retaining bolts, as follows:
  1. For 1987-94 vehicles, tighten the long bolts to 29 ft. lbs. (17 Nm) and the short bolts to 97 inch lbs. (11 Nm).
  2. For 1995 vehicles, tighten the water pump-to-block bolts to 22 ft. lbs. (30 Nm) and the water pump-to-front cover bolts to 11 ft. lbs. (15 Nm), plus an additional 80° rotation.
  1. For 1992-95 vehicles, install the torque axis mount, as follows:
    1. Attach the torque axis engine mount bracket assembly to the front of the engine using the 2 bolts and nut.
    2. Replace the 2 upper bolts previously removed from the torque axis engine mount, and attach the mount and plastic clip for the A/C lines.
    3. Tighten the 2 lower bolts that were previously loosened on the torque axis engine mount.
    4. Adjust the engine height to align the torque mount with the torque axis mount bracket.
    5. Insert the through-bolt, attach the retaining nut and tighten to the specifications shown in the accompanying figure. Remove the engine support and lifting fixture.
  2. Install the water pump pulley and secure with the retaining bolts.
  3. Connect the radiator and heater hoses to the water pump.
  4. Install the serpentine drive belt.
  5. Connect the negative battery cable.
  6. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Check for leaks and top-off the coolant.
Hope this help (remember comment and rated this; TY for using Fixya.
Mar 31, 2010 | 1992 Buick LeSabre
How do you replace the alternator on a 2000ford contour
2.0L Engine
  2. Remove air intake resonators.
  3. Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
  4. Unplug the connectors and remove the cables from the alternator.
  5. Raise and support the vehicle.
  6. Release the drive belt tensioner and remove the drive belt from around the alternator.
    NOTE It is not necessary to remove the drive belt from the engine.
  7. Remove the alternator mounting bracket bolts and remove the mounting bracket.
  8. Lower the vehicle.
  9. Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle.
  11. To install:
    1. Place the alternator into position and install the mounting bolts finger tight.
    2. Install the power steering hose bracket and tighten the retaining nut and bolt to 70-106 inch lbs. (8-12 Nm).
    3. Raise and support the vehicle.
    4. Install the alternator mounting bracket and retaining bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
    5. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
    6. Lower the vehicle.
    7. Tighten the alternator mounting bolts to 15-22 ft. lbs. (20-30 Nm).
    8. Install the alternator connectors and the cables. Tighten the terminal nut to 80-97 inch lbs. (9-11 Nm).
    9. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
    10. Connect the negative battery cable. To install:
Sep 28, 2009 | 2000 Ford Contour
How to check alternator, and how to replace it.
  2. Disconnect the negative battery cable.
  3. Temporarily loosen the water pump pulley bolts, 1.6L (VIN 3) engine only.
  4. Remove the front air intake inlet pipe bolts, 1.8L engine only.
  5. Remove the top hose from the air intake inlet pipe, 1.8L engine only.
  6. Remove the air intake inlet pipe clamp and the pipe, 1.8L engine only.
  7. Remove the power steering pump, 2.0L engine only.
  8. Remove the power steering pump bracket, 2.0L engine only.
  9. Remove the alternator B terminal cover cap.
  10. Disconnect the alternator electrical connections.
  11. Loosen, but do not remove the alternator pivot bolt and the tensioner mounting bolt.
  12. Remove the drive belt(s); relieve tension on the belt by rotating the adjustment bolt.
  13. Remove the water pump pulley, 1.6L (VIN 3) engine only.
  14. Remove the power steering pump, 1.6L (VIN 3) engine only.
  15. Remove the power steering pump bracket, 1.6L (VIN 3) engine only.
  16. Remove the alternator tensioner mounting bolt and the belt tensioner.
  17. Remove the alternator pivot bolt.
  18. Loosen the bolt at the base of the adjusting bracket and rotate the bracket up.
  19. Remove the alternator.
    0900c15280028419.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-1.5L and 1.6L (VIN 5) engine shown
    0900c1528002841a.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-2.0L and 1.6L (VIN 3) engines shown
    0900c1528002841b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-2.4L and 2.7L engine
To install:
Jul 29, 2009 | 2002 Kia Spectra
Changing the starter on a Kia Spectra
Here's step-by-step instructions on how to access, remove and re-install your alternator. Hope it helps! Have a great day!
Alternator Kia_Sephia_Rio_Spectra_Optima_1998-2006
  19. Remove the alternator. 0900c15280028419.jpgAlternator mounting—1.5L and 1.6L (VIN 5) engine shown 0900c1528002841a.jpgAlternator mounting—2.0L and 1.6L (VIN 3) engines shown 0900c1528002841b.jpgAlternator mounting—2.4L and 2.7L engine
To install:
Nov 23, 2008 | 2003 Kia Spectra
Plumbing Logo
847 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
