Question about Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
I just purchased from the original owner, a complete canon ae1 package, lady said it worked just fine. my question is: dos a battery need to be in the camera for the shutter to work? i took out the old battery, no corrosion at all. before i go try to find a battery, want to know if battery must be in before shutter will work, thanks!
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Posted on Aug 27, 2007
SOURCE:
Free owners manual ae1 canon film camera
You may download a copy of the AE-1 manual here.
If you have an AE-1 Program, you may download its manual here.
Dec 02, 2011 | Canon Eos 10d 20d 30d 1v Ae1 A1 Ef Ef-s
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
The Film advance lever wont move, the shutter button does nothing(i can push it down but nothing happens), and the button on the bottom is stuck in. In both cases this happened when there we no film in the...
Okay this is completely on memory. With the button on the bottom pushed in the camera is waiting for your to rewind the film back into the canister after this is done lift the wheel (not the crank it can break) the wheel is just below the crank and the back of the camera will open so you can take the film out. Reload a fresh roll close the door and advance to the first frame you are back in business again.
Jan 08, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have acquired a Canon AE-1 and an AE-1 Program SLR cameras and both of the film-advanced levers will not advance the film. Both of the levers only crank back about a 1/3rd of the way. I would like to...
This is a very common fault now on almost all AE1's and related models like the AV1.
Most of the time, it's due simply to age and dried out lubricants. The cameras need a strip down, thorough clean, and reassembly using fresh lubricants (known as a CLA service). It's wise during this process to remove and replace all light seals and mirror buffers as they'll have turned into a corrosive sticky black goo by now. The job is for professionals only due to the need for special tools and skills and the need to readjust the shutter speeds upon reassembly. Although it's not cheap (£80-£100 parts in the UK, cheaper in the USA and much cheaper in some Far Eastern countries such as Malaysia. If broken parts need replacing there is an extra charge), it's far cheaper than any new camera of the same quality and will ensure that the camera gives many more years of service. A freshly CLA'd camera has a resale value, a broken AE1 is usually completely worthless.
Aug 16, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
253 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
