Electronic gadgets I bought LED string lights from China which worked when plugged in but immediately began to smoke and melt at the globe points. The company replaced them but the second set did exactly the same thing. The voltage specs are listed at 110V-220V and I'm in Australia where we use 230V but this shouldn't be the problem. What's causing the thing to smoke and melt and how can I fix this problem? Cheers - ilumio
  • Dom Di Lallo Jul 10, 2013
    I don't know why my question ended up in Remote Controls when I keyed in LED string lights!
    Top Expert:
  • 12,223 Answers
O.k you must see if there are some switch for to put the input in 110Vac or 220Vac. since you have 230vac in australia, if you are in 110vac, the lights will burn inmediately.
If you have in 22ovac switch, if you have 230vac, the tolerance voltage +-10% is NOT problem for to burn, is BAD design for the manufacturer. However you must try to install in another receptacle since, you can have some overload in the line. use the amperimeter.
God bless you
Posted on Jul 10, 2013
We moved our tv to anothor room and now all it does is light up the name when turned on. Nothing else will work. Everything is hooked up correctly
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Oct 16, 2017 | Televison & Video
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
LED Mini-light string stopped working
these lights have what is called a driver it should be either a 12 or a 24 volt DC output this driver can usually be replaced never worked with this specific light though installed the freezer led case lighting at all smiths stores
Feb 09, 2013 | Home
How to cut to size christmas light strings
If you cut the line it would reqier less power so inturn may blow the globes.. it can be done but i woulden advise it if you dont know your electronic basics...
Oct 21, 2011 | Christmas Lights Etc Santa's Toy Truck
How to set the proxy settings to apply free internet
Creating an Access Point Go to SETTINGS > APPLICATION SETTINGS > BROWSER PROFILES then create. SET NAME: any ACCESS POINT NAME:For globe: http.globe.com.ph For smart: internet For sun: minternet For red mobile: redinternet HOME URL:For globe: http://www.globe.com.ph/globe.asp (http://www.globe.com.ph/globe.asp) For smart: http://wap.smart.com.ph (http://wap.smart.com.ph/) For sun: http://wap.suncellular.com.ph (http://wap.suncellular.com.ph/) For red mobile: http://m.redmobile.com (http://m.redmobile.com/) Proxy address: 64.255.180.253:80 Linger time: 300 Leave the rest as is. Then SAVE and choose it.
APPLICATION Choose Games and More then > More> Connection > choose your new access point settings . [INDENT] +++
for the settings of your handler: OM5handlerUI
Custom Http server: http://twitter.globe.com.ph
Custom socket server: socket://mini5beta.opera-mini.net:1080
leave the rest blank.
For Om4.2Handler UI
Custom socket server: socket://server4.operamini.com:1080
Front query: twitter.globe.com.ph
Remove string from URL: global-4-lvs-usa.opera-mini.net
leave the rest blank again
hope this helps.
remember : your load should be lower than 5 to have free intrnet
OR you can get it here: www.free-codecs.com/download/iphone_pc_suite.htm www.brothersoft.com/.../mobile-phone-pc-suite.html www.soft82.com/categories/Windows/mobile-phone-tools/ www.geekblogger.org/.../china-mobile-pc-suite-download-free.html
GoodLuck
Jul 28, 2011 | Samsung Star GT-S5233 Cell Phone
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
How to connect internet in my china phone n100?
i like to connect enternet in my mobile...
Feb 04, 2011 | Cell Phones
What is the gprs settings for china phone 9000c blackberry clone for globe provider?
bought a similar unit yesterday blackberry 9000c and Im quite lucky to be able to successfully configure its gprs settings for globe and sun.
You may try this out:
Smart 3G/Internet
  • Connection name: Smart Internet
  • Access point name: internet
  • Username: blank
  • Password: blank
  • Proxy: blank
  • Proxy port: blank
  • Homepage: http://m.smart.com.ph
Smart GPRS
  • Connection name: Smart GPRS
  • Access point name: smart1
  • Username: blank
  • Password: blank
  • Proxy: 10.102.61.46
  • Proxy port: 8080
Smart MMS
  • Connection name: Smart MMS
  • Access point name: mms
  • Username: blank
  • Password: blank
  • MMSC: http://10.102.61.238:8002
  • MMS proxy: 10.102.61.46:8080
If you're too lazy to manually tinker with the settings, however, you could opt to text SET to 211 and follow the instructions. It'll cost you, though, and you'll need to key in a PIN (1234).
Once you've entered the values stated above, you'll need to activate them. To do this, simply text MMS ON and 3G ON to 333.
Sun 3G/Internet
  • Connection name: Sun INTERNET
  • Access point name: minternet
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: http://www.suncellular.com.ph
Sun GPRS
  • Connection name: Sun WAP GPRS
  • Access point name: wap
  • Username: blank
  • Password: blank
  • Proxy: 203.138.159.78
  • Proxy port: 8080
Sun MMS
  • Connection name: Sun MMS
  • Username: blank
  • Password: blank
  • MMSC: http://mmscenter.www.suncellular.com.ph
  • MMS proxy: 203.138.159.78
  • Proxy port: 8080
Globe 3G/Internet
  • Connection name: MyGlobe INTERNET
  • Access point name: internet.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: www.globe.com.ph/globe.asp
Globe GPRS
  • Connection name: MyGlobe GPRS
  • Access point name: www.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: 203.177.042.214
  • Proxy port: 8080
  • Homepage: http://www.globe.com.ph/globe.asp
Globe MMS
  • Connection name: myGlobe MMS
  • Access point name: mms.globe.com.ph
  • Username: blank
  • Password: blank
  • MMSC: http://192.40.100.22:10021/mmsc
  • MMS proxy: 203.177.042.214
hope this info helps.
Jan 16, 2011 | Cell Phones
Please describe your issue or question (*) Last year we bought four of the Gemmy Color Chasing Light Show strings with the multi-color LED tear-drop shaped bulbs (#0293751). All four strings worked...
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
Dec 07, 2009 | Gemmy Toys
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
