Question about Garden
Craftsman lt2000tractor model num 917-272850
I tried to crank my tractor and all it does is click, each time i try. battery had a full charge on it and crank at first. now it wont.
da420bmx
  • 4 Answers
SOURCE: 19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
Posted on May 19, 2009
  • 376 Answers
SOURCE: Engine won't Start
If you have 3 qts. of oil in your mower, drain it immediately. It only holds 3 PINTS or 48 ozs or 1 1/2 qts. Next, remove your spark plug and put the end away from the hole (to prevent possible arching and fire) and crank the engine over. Probably, a lot of oil/gas will blow out, clearing your cylinder. Clean the plug and try to restart. If it still reaches a point where the engine will not turn past while trying to crank, the valves need to be readjusted. Also check by smelling the dipstick that there is no gas mixed in the oil. That would mean your carb needle and seat are leaking.
Posted on May 24, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
erpaalai
  • 999 Answers
SOURCE: LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Posted on Jun 29, 2009
SOURCE: Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
Posted on Jun 11, 2010
The riding mower want crank why?
Because the charging circuit in the mower has failed. Usually caused by a faulty voltage regulator.
Sep 02, 2016 | Craftsman Garden
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine clicks when i turn key, how do I determine if it is the solenoid or starter?
try jumping the battery with your car battery first. if it cranks, charge battery and possibly adjust valves. If not, try jumping directly to the starter. If that works, replace the starter solenoid. If not, might be the starter itself.
Jun 01, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding lawn mower battery won't hold a charge
It is a battary issue, however it sounds like the engine is not charging the battary so it goes flat, or there is a drain on the battary .
Jun 27, 2013 | Craftsman Garden
Riding lawn mower stopped working, now it just makes a clicking noise when you turn the key, the grass was pretty high when this happened...did the engine blow?
clean the battery posts for one, and make sure the unit has a full 12 volts in the battery ,, these units charge slowly as it is, and if the battery gets to low, the machine will just quit, you try and start them, and all you get is a click
Jun 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have not used my lawn tractor for a long time. now it just CLICKS when I try to start it.
battery does not have enough charge to spin the starter, you might be able to charge it up. try jump starting from a car battery then mow your whole lawn without stopping. if it restarts after that you are good to go, if not go to walmart and spend 25 bucks on a new battery. replace the gas first.
Apr 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jumpstart my battery twice, added water, buzzing not starting
THE BATTERY IN THESE ARE A JOKE.. TAKE IT OUT CHARGE IT FULL ! AND BRING IT TO YOUR LOCAL AUTO PARTS STORE TO HAVE IT CHECKED ... VOTE !
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
May 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
